Question about RCA CC6262 Camcorder
WHITE SCRREN I CAN ONLY SEE A WHITE SCREEN THROUGH THE LENS EVEN WHEN I TRY TO PLAY THE VIDOE I HAVE INSIDE WHAT COULD BE THE PROBLEM? MARTIN
  • WJJ22 Jul 01, 2008
    I ALSO GET JUST A WHITE SCREEN WHEN I TURN MY CAMCORDER ON. I HAVE REPLACED MEMORY BATTERY AND ALSO PURCHASED A NEW CAMERA BATTERY WITH THE SAME RESULTS. IT DOESN'T MAKE ANY DIFFERENCE WHAT MODE YOU TRY (VCR, AUTO OR MANUAL) I STILL RECEIVE THE SAME RESULTS. WHITE SCREEN. PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!
Phone white screen
Most likely its been near outside electric charge for a time... Best advice I can give is that leave the battery out for few hours, take sim out and re-install. Hope for the best. Could be that some component has burned inside the phone.
Aug 16, 2013 | Cell Phones
Dropped on hardwood floor can still make and receive calls but external scrren pure white and internal black
Hi there
Your screen hit the wood badly that is why you have a black and white screen..
The solution to this problem is to fix a new screen for your phone .
Cheers!
Jul 03, 2010 | Cell Phones
My scrren goin white
THERE IS 2 SOLUTION I RECOMEND,FIRST CHANGE THE FLAKES OR RIBBON & TRY TO REPROGRAM..CELLPHONE TECH.IS NECESSARY!!!
Mar 26, 2010 | Motorola Mobility KRZR K1 Cellular Phone
Dvd will not play
Hello dbbnewton, hi, chances are you dvd lens is dirty, you can buy aftermarket lens cleaners from doi it your self fix it stores, or hard wares, even in computer supplies, or you can use a clean ear bud, use one side wet it with warm water, and gently swab the lens, and the other side of the bud dry swab the lens, do it several times until the lens reads the dvd, just make sure you dont leave cotton resudue on the lens.
Dec 15, 2009 | Venturer PVS3368 6.2 in. Portable DVD...
Blurry out come
Hi George
It sounds like a lens issue... Try:
1. cleaning lens (carefully!)
2. Could be condensation I suppose. Unlikely but make sure its fully warmed up and dry.
3. It could be a lens element misaligned possibly due to impact damage. Needs pro repair then.
4. Just a wild thought - it's not been left permanantly in some close-up mode giving a very out of focus effect?
Hope this helps,
Regards
Martin
Jun 21, 2009 | Olympus ? 1030SW Digital Camera
Play back is in black and white
Set your TV in auto mode or according with your CAM system PAL or NTSC and some of the CAM you can set for AV out in PAL or NTSC system
Cheers
Nov 03, 2008 | Sony Handycam CCD-TRV308 Camcorder
Black scrren in record mode
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Jul 24, 2008 | Sony Handycam CCD-TRV68 Camcorder
Dell pc not working
Try to clear first cmos settings and if it wont work soo u have a problem with VGA OR MOTHERBORARD
Nov 04, 2007 | Compaq Presario Notebook
RCA CC6262 Camcorder Logo
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
