Been trying to disconnect that cable to no avail, very secure, tried force
Any suggestions on disconnecting cable, dont want to snap it. the end is thick plastic about 1 -1 1/4 inch W by about 1/4 inch H. looks like holes extend out on each side of cable on the adapter part but see no screws, all white plastic like rest of adapter. been yanking & oulling to no avail. i am 270 lbs. so are u sure this is ok to disconnect.
  • bjn7295 Jun 28, 2008
    that was it, thanks, glad i did not snap them, i am novice---on my way to next step, fan. no special startup after done, if i ever get there?
    thanks for your help
    patient & simple straight forward answers. no I think so or i do not have schematics, even suggested picture to him if answer did not work, which it did,
  • 3,037 Answers
It probably has clips which can be popped with a flat-headed screwdriver. Take a few pictures and send them to bestdarntootingood@yahoo.com and I will take a look if you still can't figure it out.
Posted on Jun 28, 2008
Replace clutch cable
Hi anonymous, this not an easy procedure for the do it yourself type person, I would suggest taking it to your local dealer or reputable shop, call around for best price should be around $150. But if your willing to give it a try here is the short version: remove necessary parts of the exhaust system to gain acess to the transmission side cover, next back off jam nut and turn in threads of cable end, remove clutch lever and cable end, cut all try straps securing cable, remove tranny side cover, remove ball and ramp mechanism, remove clutch cable end. Your going to need snap ring pliers. Good luck
Apr 17, 2014 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Steering column top bearing replacment
double posted, with 1999 added.
the FSM says dont reuse steering wheel bolts.. (unique)
here is an online quote to get to the combo switch
quote;
Removal & Installation
  1. Disconnect and isolate the battery negative cable. WARNING(bags can kill, my comment)
    Wait two minutes for the airbag system reserve capacitor to discharge before performing further diagnosis or service.
  2. From below the steering column, remove the three screws that secure the lower steering column shroud to the multi-function switch mounting housing.
  3. Using hand pressure, push gently inward on both sides of the upper shroud near the parting line between the upper and lower shrouds to release the snap features that secure the two shroud halves together.
  4. Remove both the upper and lower shrouds from the steering column.
  5. Remove the Steering Control Module (SCM) from the steering column.
  6. Remove the two screws that secure the left multifunction switch to the SCM .
  7. Disengage the two retaining tabs , next to the screw mounts that secure the left multi-function switch to the SCM.
  8. Disconnect the left multi-function switch from the SCM.
To install:
  1. Position the left multi-function switch onto position on the Steering Control Module (SCM) .
  2. Engage the two retaining tabs, next to the screw mounts that secure the left multi-function switch and firmly snap into place.
  3. Install the two screws that secure the left multifunction switch to the SCM. Tighten the screws to 22 inch lbs. (2.5 Nm).
  4. Position the lower steering column shroud to the underside of the steering column.
  5. Install the three screws that secure the lower steering column shroud to the multi-function switch mounting housing. Tighten the screws to 17 inch lbs. (2 Nm).
  6. Position the upper column shroud over the steering column with the hazard warning switch button inserted through the hole in the upper shroud.
  7. Align the snap features on the upper and lower shrouds and apply hand pressure to snap them together.
  8. Reconnect the battery negative cable.
Dec 22, 2013 | 1999 Jeep Grand Cherokee
Replace accelerator cable
Very easy to do. Take the old one off and you will see how easy. At the carburetor, the cable will be secured by a bracket. Unfasten it there, and then on the carb. roll the throttle back to wide open throttle, cable will be loose, lift it out of the groove it rides in and slide the end out of the throttle lever. At the firewall where cable goes to the gas pedal, there will be a rubber grommet that cable goes through. Just punch the rubber grommet out of the firewall.
Now on the gas pedal attachment, many different ways to secure it. Some just snap into a hole on back of gas pedal. If you can't see how to disconnect, take the gas pedal off-usually held to floor by two screws-and turn the pedal around to see how the cable connects. Once disconnected, the cable can be removed, usually drawn out of firewall on the engine side.
Good luck. Now the next time you have to replace it (like 25 years, !) you will know how to do it. Keep the old Honda running!
Jul 17, 2013 | 1984 Honda Civic
When the control is pushed once the door moves about a foot and then reverses. Push a second time and it closes properly. IThe control does not have to be held until the door is closed. Any suggestions?...
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the axles of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4. After checking those things, there is a "up force" and "down force" adjustment on the opener, try increasing the "up force" by turning the adjustment in the direction of MORE force.
Gary
May 12, 2011 | liftmaster Chamberlain Garage Door Opener...
Odometer not working
Could be that speedo cable has become disconnected or that the inner shaft has broken. The speed cable is connected between the back of the instrument cluster and the left side of the transmission. Check under the car that the cable is securely fitted to the side of the transmission. Disconnect it and and check on the condition of the square drive flexible shaft. The spinning of this inner shaft is what conveys the output shaft speed of the transmission to the instruments. The instrument cluster can be removed but pushing a length of coat hanger wire with right angle turn on its end between the the cluster and the dashboard surround. Turn the coat hanger to hook behind the cluster and pull forward to remove it. Try several points around the cluster. It is best to disconnect the speedo drive cable to withdraw the cluster (after electrical connections have been disconnected. check that the speedo cable is secure to the back of the instruments. If you remove the cluster completely follow the path of the speedo cable. If you have to replace the cable, tying a length of string to the speedo cable end first and posting the string down the cable path will help the re-installation enormously. Simply pull the string whilst reinstalling the instrument cluster until the end of the speedo can be got hold of. Refit the speedo cable to the transmission only after the instrument cluster is back in place.
Oct 17, 2010 | 1990 Mercedes-Benz 190
I dont know much about pc how do i get my scanner on my pc
THE steps will guide you through a successful scanner to pc interaction
  • 1
    Unpack your new scanner and set it up. Follow package directions and setup instructions to assemble any parts that need assembly.
  • 2
    Plug in your scanner and power it up.
  • 3
    Insert the setup CD in your CD-ROM or DVD drive. It should autotomatically run. If it doesn't, click on "My Computer" and then on the CD or DVD drive to open the CD. Look for a Setup.exe file. Double-click on it to launch the setup disk.
  • 4
    Follow the onscreen prompts to complete the end-user agreement and install the necessary drivers and software to run your new scanner.
  • 5
    When prompted, connect the USB cable to the scanner, then plug the other end into the USB port on your desktop PC.
  • 6
    Windows will recognize that a new device is available on your computer, and find the necessary software and drivers to install it.
  • 7
    Restart your PC if prompted to do so.
    Troubleshooting
  • 1
    Check all cable connections to be sure that they are secure.
  • 2
    Disconnect the USB cable from the desktop and the scanner.
  • 3
    Turn off your computer and let it cool down for 10 minutes.
  • 4
    Turn the computer on, then turn the scanner on. Reconnect the USB cable to the scanner. Try connecting the other end of the USB cable to a different port on your computer.
  • 5
    If none of these suggestions solve your problem, uninstall the scanner and start over.
  • Oct 02, 2010 | Epson Perfection 1670 Flatbed Scanner
    My 1984 toyota corolla needs a new speedometer cable installed.
    Removal & Installation The slightest bind in the speedometer cable can cause unpredictable behavior in the cruise control system. If the cruise control exhibits intermittent surging or loss of set speed symptoms, check the speedometer cable first
    1. Follow the appropriate procedure given previously for removal of the instrument cluster. The cluster need not be fully removed, but only loosened to the point of being able to disconnect the speedometer cable.
    2. Disconnect the speedometer cable and check that any retaining clamps or clips between the dash and the firewall are released.
    3. Safely raise the vehicle and support it on jackstands.
    4. Disconnect the cable fitting at the transmission or transaxle and lift the cable and case away from the transmission or transaxle.
    5. Follow the cable back to the firewall, releasing any clips or retainers.
    6. From inside the vehicle, work the speedometer cable through the grommet in the firewall into the engine compartment. It may be necessary to pop the grommet out of the firewall and transfer it to the new cable.
    7. When reinstalling, track the new cable into position, remembering to attach the grommet to the firewall securely. Make absolutely certain that the cable is not kinked, or routed near hot or moving parts. All curves in the cable should be very gentle and not located near the ends. Note the speedometer cable inside the housing must be lubricated with the proper lubricant before installing it to the vehicle.
    8. Attach any retaining clips, brackets or retainers, beginning from the middle of the cable and working towards each end.
    9. Attach the cable to the transmission or transaxle. Remember that the cable has a formed, square end on it; this shaped end must fit into a matching hole in the transmission or transaxle mount. Don't try to force the cable collar (screw fitting) into place if the cable isn't seated properly.
    10. Inside the vehicle, hold the other end of the cable with your fingers or a pair of tapered-nose pliers. Gently attempt to turn the cable; if it's properly seated at the other end, the cable will NOT turn more than about 1/4 turn. If the cable turns freely, the other end is not correctly seated.
    11. Lower the vehicle to the ground.
    12. Attach the speedometer cable to the instrument cluster, again paying close attention to the fit of the square-cut end into the square hole. Don't force the cable retainer.
    13. Reinstall the instrument cluster following procedures outlined previously. Road test the vehicle for proper operation.
    Feb 06, 2010 | 1984 Toyota Corolla
    My husband is not mechanically savvy. That being
    It isn't too difficult just do one at a time. Disconnect from your battery and then disconnect other end where it attaches to engine. There may be brackets along it's length that will have to be removed that secure it make sure to reinstall these on the new cables. I would suggest though before attaching your actual ends to your battery go ahead and replace bothe cables so you don't accidently arc your positive cable anywhere. It's just a safety precaution. Remove your negative battery connection before starting procedure.
    Nov 03, 2009 | 1997 Ford Expedition
    How to change alternator on 2005 Jeep Wrangler Unlimited?
    Straight out of the repair manual:
    REMOVAL
    WARNING: DISCONNECT NEGATIVE CABLE FROM BATTERY BEFORE REMOVING BATTERY OUTPUT WIRE (B+ WIRE) FROM GENERATOR. FAILURE TO DO SO CAN RESULT IN INJURY OR DAMAGE TO
    ELECTRICAL SYSTEM.
    (1) Disconnect negative battery cable at battery.
    (2) Remove generator drive belt. Refer to 7, Cooling System for procedure.
    (3) Remove generator pivot and mounting bolts/nut (Fig. 2) , or (Fig. 3). Position generator for access to wire connectors.
    (4) If equipped, unsnap plastic cover from B+ terminal.
    (5) Remove B+ cable output terminal mounting
    nut at rear of generator (Fig. 4), (Fig. 5), or (Fig. 6). Disconnect terminal from generator.
    (6) Disconnect field wire connector at rear of generator by pushing on connector tab.
    (7) Remove generator from vehicle.
    INSTALLATION
    (1) Position generator to engine and snap field
    wire connector into rear of generator.
    (2) Install B+ terminal to generator mounting
    stud. Tighten mounting nut. Refer to Torque Specifications.
    (3) If equipped, snap plastic cover to B+ terminal.
    (4) Install generator mounting fasteners and
    tighten. Refer to Torque Specifications.
    CAUTION: Never force a belt over a pulley rim using a screwdriver. The synthetic fiber of the belt can be damaged.
    Jul 05, 2009 | 2005 Jeep Wrangler
    The hood release on my 1993 chevy lumina snapped. the lever seems to have snapped from inside the car since it isnt attatced anymore. how much will this cost to fix at a shop?
    YOU CAN FIX IT EASILY AT HOME IF IT IS JUST THE HANDLE. THE CABLE WOULD REQUIRE ABOUT 1-1.5 HOURS LABOR TO REPLACE SO DONT PAY MORE THAN THAT.
    May 19, 2009 | 1993 Chevrolet Lumina
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
