Question about Whirlpool GS6NBEXR Side by Side Refrigerator
I own a three year old Whirlpool side by side fridge freezer with ice maker and water dispenser. Icemaker not now working, and fridge temperature warmer, not cooling food etc sufficiently
  • freezywest Jul 04, 2008
    Thanks Mike, thanks FixYa - solution worked a treat! Icemaker working again, and fridge temperature nice and cold again!
  • freezywest Jul 31, 2008
    Defrost timer appears to be part of printed circuit board - does that mean I will have to change the entire circuit board to fix the problem?
Ice maker will not work,i push the handle to get ice it makes a noise like the motor is running .the water works just fine .please any ideas
Posted on Aug 02, 2008
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
  • Mike Durland
    Mike Durland Jul 31, 2008
    probably, this is a major problem with some refrigerators these days.
Icemaker will not flip the new ice out from the tray. 25" whirlpool side by side-water and ice on front door A new ice maker does the same thing
This sounds like a temperature problem. Check freezer for 0 to 10 degrees.
Most im's will not flip until temp reaches at least 10 or 15 degrees for most fridges.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 19, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool icemaker not working
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees.
Jun 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
146 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
