Question about Comfort-Aire Dehumidifiers
Comfort-aire dehumidifier 501 cycles on and off
Cycles on and off 3 min at a time
  • dpressm Jun 29, 2008
    Then why come on again in a few minutes?
    What do you mean by "Set Point"
  • 828 Answers
It is possible that the humidity is below the set point of the dehumidifier. They will run for a short time until they get a true fix on the actual humidity then shut down.
Posted on Jun 29, 2008
  • James Helmer
    James Helmer Jun 29, 2008
    Set point means the level of humidity the dehumidifier is adjusted to control at.
Do you put water in a dehumidifier
No, a dehumidifier takes water out of the air where it's placed. If it's very humid in the air, you should have a tank full of water after a few hours.
Nov 21, 2013 | Comfort-Aire BHD-501 Dehumidifier
BHD-651D purchased 9-9-08 Ice builds up on coils. Filter and coils/fins clean. Air temp 72 F
What is your humidistat set at? Could you be trying to get to too low a humidity? Try to determine what the humidity is and set the stat just below that. In that way, once it reaches the setpoint, it will cycle off, allowing the coils to warm up.
If that works, lower the setting a bit more & see results.
Write back.
Gary
Aug 25, 2011 | Comfort-Aire BHD-501 Dehumidifier
My dehumidifier model BHD-501-D is icing up. The fan and compressor are running, do I need a new thermostat?
You may, but more than likely, the air intake filer needs to be cleaned and the compressor coils wiped down and cleaned. After cleaning the coils, a light coat of WD40 helps to preserve them.
Before attempting any cleaning or service work, turn the unit OFF and unplug it from the wall outlet and allow it to thoroughly thaw. Keep in mind, a dehumidifier will freeze up, if the room temperature is below 40 degrees. Also, where you have it installed may be a problem. Particuarly, a basement. Where the air temperature is colder at floor level.
In case you have misplaced your Owners Manual, I have included a link to it that you can download & print for future reference. Be advised, your Model Number is not for a Sunbeam Dehumidifier, it's for a Comfort Aire dehumidifier that's manufactured by Heat Controller Inc.
http://www.sylvane.com/images/prodphoto/co758/comfort-aire-product-manual-501-651-D.pdf
I hope this helps you solve the problem. Please let me know. Thanks.
May 07, 2011 | Sunbeam 30Pint Dehumidifier
My dehumidifier model bhd-501 won't shut off& is very hot. What might be the problem? Thanks
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 18, 2010 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifier is on but nothing happens
air filter clean.
water level switch problem.
control card problem
start at these points first........
if fan is working may be compressor.
Apr 20, 2010 | Comfort-Aire BHD-501 Dehumidifier
Comfort aire overtemperature switch part no. 47-21900-01 I am looking for this part. thanks stew
Call Heat Controller in Tennesse they distribute this although it is made by LG
Jan 22, 2010 | Comfort-Aire BHD-501 Dehumidifier
Motor
Your problem may be the thermistor that causes the CH01 trouble code.
Aug 21, 2008 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifiers Logo
199 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
