Question about Sony Playstation 3 (PS3) Console
No Display I have an HDTV with HDMI Cables. It was working fine; but now, no display. Sound but no display at all!! What do I need to do??
  • Wanttobeliev Jun 30, 2008
    Thanks, I'll be sure to try that!!!
    Problem Solver:
  • 35 Answers
PS3 is The amazing device by sony but it has some common problems like Display problem but no sound problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Mar 12, 2009
    Champion:
  • 207 Answers
Hmm ok I suggest connecting the av coords again then turn the ps3 off then on wait for the red light. Then push the power button down until you hear it beep then reset itself... common issue may take 5-10 times to work but it will!
Posted on Jun 30, 2008
Emerson LCD TV Model LD190EM1 Sony Blu-Ray Disc Player, Model BDP-S3100, The TV screen gives an error reading "Format not supported" when I connected it using either HDMI connection.
This HDTV is rated display signals up to and including 720P resolution according to the spec linked below. If you are outputting a 1080i or 1080P signal from your BD Player, this could be the cause for the error message. Many HDTVs will accept signals higher than they can display - and simply down-rez to the highest resolution that they can display.
Connect the BD Player to a device that can display the signal. Enter the player's setting and change the output to 720P. Shut it off / disconnect cables as needed and reconnect it to the Emerson HDTV and see if it will display properly.
If it does, you're all done! if it doesn't - there's something else going on that isn't readily apparent to me. Good luck!
Emerson LD190EM1 Specs CNET
Mar 03, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Help with HDMI cable error
switch the HDMI cable end for end, maybe try a different port
Jan 06, 2015 | Olevia 42" 242-t11 1080i widescreen hdtv...
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
I have an RCA D52W20 that I connected to my PS3 with an HDMI/DVI Cable. The display is fine in 480i. However, No sound is coming from the TV.
This is normal my friend. A dvi port can't use audio even if it is using a hdmi cable. A easy fix is to connect your A/V cable into your ps3 and connect the red and white cables next to your dvi cable or connect it to your stereo. After that go into your setting, go to audio setting, click on audio output, and select A/V cable. it should work after that.
Mar 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
May 26, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
