Question about Sharp Notevision PG-M10X Multimedia Projector
Video turns on and off
I bought a used pg-m10x, so even though it claims to only have 70 hours of use, I don't know the actual number. I have two problems:
One, I can't get the projector to work with a laptop. I haven't tried a desktop yet, because I don't own one. Occasionally I can get it to make a picture, but its wavy, often in triplicate, and the colors are way off.
The second, and more important problem, is that the video cuts off momentarily, usually for about 5 seconds at a time at random intervals. The projector will also make a little beeping noise when this happens. The bulb does not seem to turn off when this happens, it is just the video that cuts out. Also, seemingly related to this, is that some of the times it starts up it won't turn on and the red light next to the "on" light turns on.
Can you help me with these problems?
Thanks,
Justus Cade
Hi, Switch the input to RGB, you will need the remote to do this.
Posted on Feb 01, 2009
Hp probook keyboard
most likley a loose cable or "ghosting" go to your local pc shop for help
Mar 08, 2014 | Computers & Internet
PS3 Power Surge.
Get a surge protector for your most loved systems, that way the worst case scenario is you will need a cord replacement. Unplugging it when it's not in use may also cool it down.
Jul 24, 2013 | Sony Playstation 3 (PS3) Console
Loud buzz/whirring noise, need help diag and fix
If Samsung the color wheel (part number BP96-01579A) is suspect number 1.
Wheel turns at over 8,000 rpm and commonly fails= High pitched sound or fan like sound---and when it fails (shatters) you will have a grinding sound and set should shut down.
There is an easy way to know---with owner manual remove the lamp unit (its a cartridge) and look where the lamp faces--if pieces of the wheel are missing etc the wheel is gone.
Most of the wheels are customer replaceable if you are handy. You Tube even has video instructions for most models for this repair--most sources that sell the part also provide instructions--for a first time person doing this it takes around a hour.
see attached photo of typical color wheel.
Apr 16, 2012 | Samsung HL-S6187W 61 in. HDTV
I have a General Lee radio. Bought it used from a pawn shop for a really good price ($70, don't think they know what it is). I turned it on worked great, for maybe 12 hours off and on. The next day it...
depending on how old it is, it could have bad caps. Could be the switching transistor, mic... Any number of things. It is the kind of thing where you have to start checking things down the line looking for the issue. Start with the simple things like the mic, cold solder joints. Look for obviously burnt parts. After that it gets a bit more technical checking parts in the TX section.
Hopefully its just a bad mic wire which would cause the radio to have no RX. Try a new mic. Good luck!
Aug 11, 2011 | Radio Communications
Turning on and off all by itself
Owners Manual, Pg 18, TV Auto Function.
"If a video feed is connected to the TV VIDEO IN jack during the installation, that signal is used to trigger system turn on. Even when the receiver is turned off, the presence of a signal at the TV VIDEO jack will automatically cause the receiver to turn on. As long as the signal is present, the receiver will remain on. When the TV or other source is turned off, the receiver will automatically retrun to a standby mode within five minutes."
Try using a another video input.
Jan 12, 2011 | Harman Kardon AVR 70
I can't fill up the 2MB limit to the maximum. It stops loading at approximately 70%.
Even though your player gas a capacity .is 2mb.The actual memory which you can use is around 70 to 80% .Because rest of the space is used to store protected system and boot data.The same happen in every memory device, be it a thumbdrive , memory card etc
Oct 17, 2009 | Audio Players & Recorders
Poor gas mileage on 2008 Ford taurus
Are you using the correct grade of fuel.
Manufacturers claim that a car will do 28 to the gallon.
This is done under ideal conditions at a constant speed on a rolling road.
Wind, hills, overtaking and tire pressures will decrease fuel mileage.
Your car is ok. Don`t expect much more unless you want to drive at 56mph
good luck
Jan 25, 2009 | 2008 Ford Taurus
Flickering image
Have you check your cable? Are you using the component(RGB) to vga cable? Your vga to vga cable may be defective.
Dec 12, 2008 | Sharp Notevision PG-M10X Multimedia...
Could not get more then 72hours using 20lb tank on low
HI. propane has 91000 btu's per gallon. 20# bottle has 4. divide btu's of heater by #of gallons for hours of use. I have the same heater and I think the med. setting both burners on is more the 7000 btu's.
Mike
Nov 25, 2008 | Dyna-Glo Double Tag-a-long Heater
Sharp PG-M10X projector
Tel 703 377 7121 Hi Allan
It might be a digital or optical problem. This symptom was often part of the CRT type projector setup but i have not seen in the digital single lens type.
Is the lamp sitting 100% proper. Have you displayed the content machine and source on another display device? Was the machine dropped or knocked? It is an unusual symptom to have just be replacing the lamp..so something else has occurred.
If a digital problem in could either be a circuit malfunction or software (IC rom issue)
Re your Sharp PG-M10X We are able to supply replacement lamp delivered next time you need one, as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens.
http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
May 23, 2008 | Sharp Notevision PG-M10X Multimedia...
Sharp Notevision PG-M10X Multimedia Projector Logo
118 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
