Question about Carrier 38CKC036 Air Conditioner
FAN IS NOT WORKING ON MY CARRIER UNIT
Two days ago, the fan stoped working. I don't smell anything, when I placed my hands on the unit, I can feel there is some electricity sensation and sometimes I can hear some noise for 2 secs.
I spoke to a friend and he said it may de the condensation system. Unit is from 2004, does it have still warranty on it?
  • byag Jul 18, 2008
    Blower fan is not working but compressor is. Increased the temperature setting to stop the compressor. I took the panel off the furnace/blower unit and nothing seems amiss other than some mold after 9 years service. There is a low hum although the power is off too the unit.
    Genius:
  • 1,036 Answers
It sounds like it is the run capacitor on the fan motor is defective.
Typically when this fails, the motor will buzz, and get hot - without rotating. When it gets too warm, the temperature cut-out will shut it off untill it cools down.
Try replacing this with one of a similar value or a genuine part.
I don't think it is under warranty after this time.
Posted on Jun 28, 2008
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
When the unit is turned on, for the first 15 minutes or so, there is a distinct stale mouldy smell. I suspect dust collected on the unit coils is being wet by condensensation and it smells as the first air...
You can check the cause of that smell if you have the tools to open the unit. The first test is to place a piece of paper in front of the evaporator and start the fan. If the paper is **** or stays in front of the evaporator, you have a clean evaporator. If it is not ****, you need to open and clean the unit. The blower may be filled with dust and molds. It is best to find someone who knows how to work and clean your a/c unit
Sep 10, 2011 | Carrier 52PQ307 Wall/Window Air...
The fan in my husband's Focus stopped working a few days ago. He can feel heat when he puts his hand close to the vent but there is nothing blowing the heat out. He checked the fuses and replaced the...
Hi its ounds like the fan has failed, the fan blows the heat into the vents without it, it will just remain in the heater core. other possibility and very common also is the cabin heater regulator they ofetn go, located in the middle of the car looking into the engine compartment has 2 pipes one in one out, feel the pipes see which is hot etc and get back to me.
Regards
Dan
Dec 31, 2010 | 2000 Ford Focus
Window A/c 10 or 15 days is good working\r\nbefore !0 or 15 days ago all Eveporater and section line freeze fan moter good praper work melt the freeze and A/C on A/C giving good cooling what is problem
Hello
You may try cleaning the evaporator filter,Also cleaning the outside coil or condensor,Simple green works good for cleaning coils and a garden hose.
Also cleaning the evaporator may help.
When unit is running properly the evaporator should feel cool and wet from top to bottom.
Last,the unit could be low on freon.
Jun 10, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
No heat after burnt smell
Either your Fan motor is faulty or the fan control resister assembly is burnt out, either of those will cause the smell.
Dec 28, 2009 | 1999 Cadillac DeVille
My new hunter fan feels hot when its on high and smells funny but its only been used just this once since i installed it a couple of days ago is this normal
Yes. The outer paint on your fan motor gets heated up first time and when new it does give off some kind of smell. But after a few hours of use the smell should disappear. Smell can come from the winding also.
Oct 17, 2009 | Hunter 52" Ceiling Fan With Light And...
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Outside unit won't turn on. I can hear the power
Could be anything from a bad contactor to a blown capacitor. Fan motor might have failed causing the compressor to quit in overload (MORE)
Jun 10, 2009 | Carrier 38CKC036 Air Conditioner
Clicking/knocking sound and feel when shifting & smell
first check the clutch hydrolic fluid. If it's low or leaking, it may not disengage the clutch completely causing the disk to drag (and smell) The knocking sounds like you're loosing the thowout bearing and/or possibly the disk (there are cushion springs that may have come out of place). Take it to a transmission shop that does free diagnosis. anything other than fluid-related is going to be pricey.
dont forget to rate ... and dont shoot the messenger
Jan 03, 2009 | 1999 Volkswagen Beetle
Carrier 38CKC036 Air Conditioner Logo
287 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
