Question about True TBB-2 Beverage Cooler
True TBB-2 Cooler issue
I have a True TBB-2 Beverage cooler in my house and it is leaking rusty looking water from the top. I thought the drain might just be clogged b ut it wasn't.
  • 122 Answers
BY to I take it yu mean top area inside cooler. If that is the case and yu are sure the drain is clear it could possibly be one of the following.
1: rusted/ corrodid evaporator drain pan
2: coil in cooler partially frozen
Posted on Sep 23, 2009
How do you remove the evaporator cover on a Tbb-2 cooler?
PDF]True Manufacturing Company, Inc. - Fixitshop.com
https://fixitshop.com/manuals/TECHNI~1.PDF
Top Removal for TBB and TDD ... Top Removal for Various Coolers - TSSU, TWT, TUC ... End Cap Replacement-T-Series Swing Door ... GDM 2 Door Cooler IDL Light Diagnosis ... If you keep the Condenser clean you will minimize service ...
[PDF]installation - True Manufacturing
https://www.truemfg.com/assets/...Website/TDB_TBB.../tbb_english.pdf
Your TRUE cooler when properly maintained will give you many years of trouble-free service. TO LOCATE REFRIGERANT ..... Removing bracket from skid. Removingbracket from cabinet. 1. 2 .... tab holding the door cord slides out the back. ... The switch is located on the front of the evaporator housing toward the front of .
Nov 08, 2015 | True TBB-2G-S Stainless Steel Beverage...
TRUE TBB-2G Cooler is leaking water from the fan
I would guess the water is dripping from an ice ball or buildup in the coil either from an inlet side of the coil blocked by an accumulation of dirt and dust or paper or such. Second, if you leave the door open for lengths of time ice will build up, also an over heated over loaded condenser will cause ice buildup. In any case if you shut it down, let the ice melt, clean the coil, keep the door closed as much as possible and if its hot where its sitting let it have some air it should improve. Last thought, if there is a refrigerant leak in the system ice will accumulate at the end of the coil, the compressor will stay on longer than normal and this water drip is letting you know a service call is coming soon. Hope this helps and good luck.
Aug 12, 2014 | True TBB-2G Commercial Refrigerator
We have a true upright, glass front beer cooler. TBB-4-G refrigerated back bar. The bottles and cans right in the middle are icing up and forming huge blocks of ice. we have turned up the thermostat,...
Check your evaporator drain pan and the outlet for the condensate water, and make sure the drain tubing is clear. That water is supposed to drain outside the box.
Aug 30, 2011 | True TD-95-38-LT Beverage Cooler
I have a quarter inch of water in the bottom of my cooler.
check out the drain system in the very bad of the unit (inside). When obstructed it can cause the water to puddle inside the bottom. The hose is short, you can use caned air or a straw to clear this out. Don't use anything metal or sharp, you don't what to poke a hole in the tube.
Good Luck
Aug 22, 2011 | True TBB-2G-S Stainless Steel Beverage...
I have a fairly new True tbb-2gs which is on a dedicated 120V/15A circuit...has had problems in past with condenser cycling. That problem went away after unplugging and replugging the cooler back into the...
You have to verify that the compressor is running. Don't assume that it is just because the fan is running. the compressor may not be running. If compressor is running, good possibility that it is low on refrigerant. Most common and obvious.
Aug 18, 2017 | True TBB-2G-S Stainless Steel Beverage...
Ice build up and leakage in unit
The condensate drain line is clogged. Defrost it by pouring warm water and baking soda down the tube located bottom of pan under blower. Repeat until water flows easily
Apr 30, 2011 | True TBB-2G-S Stainless Steel Beverage...
If the dial is labled 0-9 what nimber is the coldest?
0 is warmwst,9 is the coldest.set it at +2C so that wine/beer dont freeze.beer is best served at 2c.
Dec 31, 2010 | True TBB-2 Beverage Cooler
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
I can't get the fluorescent tube to light up when the doors open.
Most fluorescent lighting have ballast in them it more then likely just needs replaced. I have included a how it works link for you HERE
I hope this helps you fix your beverage cooler.
Aug 14, 2008 | True TBB-2 Beverage Cooler
True TBB-2 Beverage Cooler Logo
271 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
