Question about Whirlpool Duet GHW9150P Front Load Washer
Error message: water tap closed .
Machine displays error message that water tap is closed. have checked taps and water is there. unplugged machine for a few minutes to see if some chip needed rebooting. machine is 6 months old Checked screen not plugged.
Had purchased the 5 year warranty. Luckily this unit is less than a year old. Will call Warranty Service Department on Monday
  • Anonymous Sep 01, 2008
    We are having the same problem. We returned from vacation and I started the laundry, but forgot to turn the water supply back on. It stopped and flashed the water supply code, but would not cancel or continue service when I followed the manual directions. It just flashes the 28 minutes remaining light. The door remains locked and it sounds like it is draining, but it doesn't move. Can you help us, or let us know how your problem was solved??
5 Suggested Answers
  • 105 Answers
SOURCE: error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
Posted on Jan 02, 2008
frederiquema
  • 76 Answers
SOURCE: The machine keeps indicating a closed water tap!
chek ur whater temp on ur sicle and then if dont work just turn the taps fuul power
Posted on Nov 19, 2009
  • 75 Answers
SOURCE: Can anyone help please - the red light came on
it could be a water valve fault. try to find out witch one is not letting water in. you can after doing so switch the wiring from the vavles hot to cold. run again. if you were not getting cold water and you switch the wires from cold to hot and now your getting hot when you have the cold on then you know that is a vavle problem. i hope you understand how i put that.
Posted on Jan 10, 2011
  • 6277 Answers
SOURCE: What to do if whirlpool awz 50e washing machine is
Providing that the tap is turned fully on and the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Posted on Mar 27, 2011
I have a Haier 75-981 Automatic Washing Machine (Top loader) that is displaying an error code FA. What does this mean?
Feature : Error Code-control panel display "FA"
  • Answer : Reason:Water level sensor error.
    Solution:Please unplug the machine and close the water tap, then call for service
Mar 15, 2018 | Haier Washing Machines
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Why is my machine not spinning
Well, it would help to know the make and model... on a Samsung the E8 code means the water hoses are connected to the wrong taps (i.e. the hot hose is hooked to the cold tap and vice-versa).
If it's not a Samsung, please provide more info.
Mar 08, 2015 | Washing Machines
My siemens IQ washing machine model 1434 says "Tap Closed" on the digital display and wont work. My spare washing machine works so there is nothing wrong with the taps in the plumbing. Is this a com
the water intake solenoid valve has failed
or the control board is not able to open it
i would check there it voltage at the solenoid 2 pins {mains here 120 or 240 v}
this opens the water in
if you have no voltage at the valve
then the controller board has an issue
or the door isnt detected as closed
some machines do a self test so
is there an actual error code
tap closed is no inlet
all valves have a small filter on the inlet side
use a pair a flat nose plyers too pull the filter cone out
and give it a clean
other than this the valve has failed or is seized
Aug 30, 2014 | Siemens Washing Machines
My Jura Capresso E 8 is stuck in open tap filling system. I open tap it says filling system, it says close tap, when I close the tap it goes back into open tap. Float valve looks fine, water is moving
Open the tap with frother spout off. This happened to mine and I took the frother tip off and opened tap with tip off. Water filled and I closed tap...Machine returned "Ready". I heated water in microwave for three minutes- placed frother tip in hot water and all kinds of gunk came out. Lesson learned- Do a thorough cleaning of frother by immersing it in very hot water at least once monthly- even if you don't use it
Jan 06, 2013 | Jura Capresso Impressa E8 Espresso/Coffee...
Washing machine not functioning...the service engineering has come and claims that the digital switch board is short circuited and gone and replacement would cost 2700/-Rs.....The machine stopped in...
Hi Nandita from retired Englishman in SW France,
This is a VERY difficult situation for us at FixYa to REMOTELY diagnose your symptoms. The service engineer is actually there looking at, and testing, the machine!
I will explain what the 4E and DE normally indicate and what normally to do about them ;-0)
4E Water supply error. (should clear pressing star/pause button if everything is OK)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
'DE' stands for Door Error.(should clear once the door is closed properly)
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 25, 2011 | Samsung Washing Machines
Error messages on my Ariston AVXD109
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Sep 07, 2008 | Ariston Technologies AWD121WH
Dec 08, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
145 people viewed this question
Dan Webster
Dan Webster
Sal De
