Error Warning X "Windows can not find 'C:/Windows/system/rundll.exe
  • 47 Answers
HAI,WINDOWS WILL CORUPTED FINALY REINSTAL WINDOWS XP ONLY IS POSSIBLE.
Posted on Jun 28, 2008
My windows xp no longer supports the system 32 rundII.exe connections
The rundll.exe is a critical core system file. If it has been corrupted then entire Windows is severely affected and it's too late to fix it. Make a backup of all your files while you still can and reinstall.
May 17, 2011 | Dell OptiPlex GX620 PC Desktop
What does "RUNDLL Error loading newdev.dll" and
newdev.dll is the Windows file that is responsible with the recognition of the hardware and the loading of the drivers - an absolutely critical file. This file is severely corrupted and the only way to fix that is to perform a Repair install.
Dec 15, 2010 | Dell Computer Refurbished OPTIPLEX SX270...
Rundll 32.exe
hello
Download Rundll.32.exe Repair Tool
Compatible: Windows 98, 2000, ME, XP, Vista, 7 (32/64)
How Do I Fix "Rundll.32.exe"? (Instructions) Please follow the following 3 steps to eliminate your problem:
STEP 1: dicon.png Download the repair tool
STEP 2: Install and open the tool
STEP 3: Scan & repair the found errors
please rate my service
Nov 18, 2010 | Computers & Internet
How do i remove run.dll2 from my computer?
Rundll.exe files are programs that are directly tied to the registry on Windows computers. Dynamic Link Library (DLL) files contain libraries of information used by other programs running on your computer. They were originally created in order to help computer programs run faster on the Windows operating system. When a DLL file is corrupt or missing, a Rundll error will be generated. Normally when a rundll error is generated it is related to malware.
  1. Note the process that is generating the Rundll error by examining the last file name in the error that ends in ".dll."
  2. Open the service configuration program on your computer by selecting the "Start" menu and typing "command" in the search text field. At the DOS prompt type "services:msc" and click "Enter."
  3. Select the DLL service from Step 1. Right click the service name followed by the "Stop" menu button. Exit the service configuration program.
  4. Open your computer's registry editor by typing "regedit" at the DOS prompt and navigate to the Rundll registry key by typing "Microsoft\Windows\CurrentVersion\Run" in the Search field.
  5. Select the registry key returned and in the value associated with the registry key, confirm it ends in the same DLL file name found in Step 1. If it does, single left click the value and Press the "Delete" key. Exit the registry editor.
  6. Restart your computer and the Rundll error will be corrected.
Save a tree.
Apr 28, 2010 | HP W19b LCD Monitor
Trojan Horses PSW.Generic7.APIQ, Win32, etc.
Boot into safe mode and go to your control panel > add or remove problem and delete the virus as a program on your pc.
After that please restore your computer to an earlier time when it worked bettrt.
KInd Regards
Nov 09, 2009 | Microsoft Windows XP Home Edition
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
RUNDLL
The first thing you must do is to identify the specific rundll process. This is not a difficult task; there is a vast online process library in which you can evaluate the validity of the process that is running. When the error dialog box opens make not of the process name. For example if the dialog pops up and shows you the dll error:
Error loading C:WINDOWS\ system32\ usvdgpo.dll
Visit www.processlibrary.com. Copy and Paste the dll or simply type it into the search box. The results will indicate that the program is a part of trojan spyware.
STEP 2: STOP THE PROCESS
Often you can locate the Run Dll in the exe services. You can open up your services configuration by following instructions below:
1. Open your Start menu.
2. Click Run
3. In the command screen type:services.msc
4. This will bring up the Services Management window. If you drag the mouse to one of the services. It will give you a detailed explanation of the service in question. By right clicking the individual service.
5.Stop the "dll"service immediately.
STEP 3: LOCATE AND DELETE
You will have to open your Windows Registry File System. This is an extremely delicate process. You may want to use a good registry cleanerThis will often fix the dll error in question, eliminate other errors and also speed up your computer. The registry key: HKEY_LOCAL_MACHINE> SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ RUN
This action will help you speed up your applications load times considerable. Here is how:
1. Click Start
2. Click Run
3. Type regedit
4. Find this registry key:
5. In the right section click:"rusvdgpo" = "%System%undll32.exe %System%usvdgpo.dll, [RANDOM LETTERS]"
6. Delete the value and Restart.
May 01, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
