Question about Sony VAIO PCV-RZ40C1B PC Desktop
Network cable stopped being recognized
I've used this computer with a cat5 connection to the router for years.  The other day it just stopped recognizing the connection and says "a network cable is unplugged"  Other computers get internet just fine from the same cable.
  • 550 Answers
Rj45 (cat5) sockets have 8 internal tensioned wire prongs, (six are used for cat5 ethernet)
use weakens the tension and they can be dislodged sideways vertically or disconnected from the internal cabling. Likewise solder connnections to the motherboard fail.
a possible fix is to power down the pc, and with a jewellers screwdriver ensure that all the internal wires are present, straight, aligned, and protruding across the opening.
If there are missing wires(broken) then the rj45 socket shoould be replaced at your local pc store, (not walmart)network cable stopped being recognized - a796c91.jpg
Posted on Jun 28, 2008
  • 47 Answers
HAI, THE CABLE DRIVERS ARE CORUPTED .UNINSTAL THE INTERNET SETTING AND CREATE NEW ONE THAT WILL WORK.
Hello friends How can I set up my computer win7 to the Konica minulta printer by network cable cat5 please answer very detail.Many thanks.
First, you CAN'T connect a CAT5 cable directly from your PC to the Printer. That won't work. Both have to be connected with their own CAT5 cables through a hub or router on your network. The router gives them separate IP (network) addresses so they can talk to each other.
You may need to set up the printer through a direct USB connection to your computer. Once the networking options are set, IF it's an Ethernet-capable printer you may be able to connect that way.
Jan 20, 2018 | Konica Minolta Office Equipment & Supplies
Acer aspire 5335 connects to wireless internet, but not with eathernet cat5 cable?? thanks
Make sure the Network Connection for the LAN is not disabled. Click Start/Control Panel and look for the Network Connections. Make sure the Network Connection for the LAN is not disabled. if it is disabled, right click on it and select enable.
Also the port could be bad on the computer. If it does not light up when you put the cable in the port might be damaged.
May 01, 2012 | Computers & Internet
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
How can I connect my ps3 to my computer modem?
Here is a general guide I wrote. For Vista, however, I think you will have to go to the sharing tab instead of the advanced tab when you are browsing the properties of a connection...
1. Get a CAT5 or CAT6 crossover cable. The cable that came with the PS3 is a normal Ethernet cable, therefore it cannot be used for this operation.
2. Make sure you have two sources for network communication. For example, you can have 2 ethernet ports on your computer, or you can have a wireless card and a Ethernet port etc. It helps to draw out a connection blueprint such as this:
DSL Modem > CAT5 cable > Network Card 1 > Computer > Network Card 2 > CAT5 Crossover cable > PS3
3. Connect your computer to the modem and verify that you have an Internet connection. Then, click on Start, go to settings, control panel. Double click on Network Connections, and identify the connection to your modem (Network card 1).
4. Right click on the modem connection, and choose properties. Next, click on the advanced tab (Sharing tab for Vista users), and check the “allow other users to connect…” checkbox. After the checkbox is checked, click on the “Home networking connection” drop down box and select the name of the second network connection. Click OK and exit the properties window.
5. Finally, connect the CAT5 crossover cable from the second network adapter of the computer to the PS3, and voila, your Internet connection is now routed to your PS3. Please be aware that your computer must be on in order for your PS3 to stay online. In the long run, a router may be a much better device to use than your computer, since it consumes only a fraction of the electricity than your computer does.
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My internal wireless adapters will not connect to WPN284 wireless
Make sure the default gateways and DNS servers options for both wifis point to your wifi router
Mar 30, 2009 | NetGear RangeMax WPN824 Router
How do i hook up a router
Let's proceed first with the physical connectivity. Please follow the steps below:
1. Make sure that your computer is working when directly connected to the modem.
2. Connect the CAT5 cable of your modem to the WAN port of your GWA504.
3. You should have another CAT5 cable. That CAT5 cable will be connected to any one of the LAN ports on the back of that router.
4. Connect the other end of the CAT5 cable to the network card of your computer.
5. After the physical connection, just let me know and we will proceed with the next steps. Because your statement is very broad. We have to consider lots of things here. Please reply so that I could further assist you.
Mar 27, 2009 | IOGear GWA504 Router
ati catalyst is for a graphics card.
it would not have issues.
the card may show as fine, or the drivers may. try the card in another pc. if it is built in try a new card. ethernet cards are just a few pounds.
Feb 25, 2009 | Computers & Internet
Sony VAIO PCV-RZ40C1B PC Desktop Logo
93 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
