Question about Brother Office Equipment & Supplies
Can I use the fax and phone on the brothers printer without hooking it to my computer, just to the phone line?
  • 550 Answers
Not knowing the model of the printer there is no definitive answer
but
a printer/fax with a fax scanning unit built in can be used as a standalone fax
Posted on Jun 28, 2008
Need to hook up a brother MFC-210c so it can fax
Install the software (Brother MFLPro0 relevant to the printer. If you do not have the original CD download the appropriate suite from Brother Solution Center.
When you install the software you will be asked to choose USB, or Local Network. You can always install the USB and connect the printer to the calculator through USB. Different installations for different connection types (USB, LAN)
After you configure the software, you can open the Control Center 3 software and use the fax.
To be able to fax, you need to connect a telephone cable to the port marked line. After you do try pressing the unhook button. If connection to the phone line is correct you will hear the tone.
The MFC can fax without being connect to a computer, just the phone line.
Jul 30, 2012 | Brother MFC-210C All-In-One Printer
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
I got a new computer EMachine. I wanted to hook up my Brother MFC 420 using my CD, but no luck. Maybe I have it hooked up wrong. My last computer had a telephone line hook-up. but new one doesn't. I...
Hello s_fields75. I just read your problem and was wondering if you checked your cable connections. You stated that you may have hooked it up wrong. I would definitely make sure your cable connections, USB, etc., are correct. The printer is an all-in-one and should just automatically find the connection through your modem for the fax feature. If not, you might need to get a splicer for your phone line (you can pick one up at radio shack for less than $10). Unhook your phone line from the wall jack. Plug in the splicer into the wall jack, then plug the phone cable into one jack and your fax phone cable into the other. That should do the trick. If not, you may need to download an updated driver from emachines or brothers' websites. Hope that helps!
Sep 22, 2010 | Brother MFC 420CN All-In-One InkJet...
No dial tone when pressing hook fax is returned
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 06, 2010 | Brother Multi-Function Center MFC-240C...
How to hook up phone lines? on Brother MFC-5890cn I don't have a manual on where the fax lphone line goes
The phone line goes to the plug marked L or line, the one with the picture of a phone is for an answer machine.
Jan 30, 2010 | Office Equipment & Supplies
Cannot fax with printer cartridge (Brother MFC 3100c)
Nice try, but it won't let you do it, will it?
Kind of frustrating, since you thought that way you might get around the cost of new cartridges, no? Here's the brother support site if you really want to delve into it. But I don't thin so.
You can, on the other hand, send a fax from your computer over the fax/modem, if the document you want to send is already in the system somehow. If you need to scan it in with that same printer you're probably out of luck. But if you have an installed fax modem and are hooked up to a phone line, you can use Word or the modem software to configure and send faxes.
Good luck. There's alway Kinkos, I guess.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 26, 2009 | Brother MFC 3100C All-In-One InkJet...
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
How do I hook up my fax on my
Only way to use internet and fax simultaneously is to get DSL
Nov 01, 2008 | Brother MultiFunction Center MFC-440CN...
Brother mcf-440cn
Jacki
 Must have DSL filter attached before fax, not sure how you are saying you have it setup, but phone line should come from wall then to filter then to fax socket marked line, phone should be hooked to socket on fax marked EXT, if you dont have dedicated fax line then fax number will be same as phone no.
If you have Adsl then there will be a lead from wall that splits into two, one goes to your modem (ADSL) and the other marke phone or line needs to go to fax socket marked LINE
Oct 21, 2007 | Office Equipment & Supplies
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
