-   Coffee side has stopped working. If I switch to espresso side, the light comes on (I turn it off before ot starts) but if I switch to coffee side...nothing. No light on at switch, burner desn't heat, coffee doesn't brew.
If the problem is in the switch, will replacing just the knob in front work...or is there more to it?
The machine is less than two years old.-   Guest
Popular Solutions for Krups XP 1500 Espresso Machine
I fill the 2-cup thing full to almost the rim, then mash it in using the circle on the end of the...
(More)
I fill the 2-cup thing full to almost the rim, then mash it in using the circle on the end of the scoop thingy. I learned not to smash too hard, as my machine doesn't like that. After it has warmed up, I put the espresso "bowl" thing with the handle onto the machine, locking it in place. I then hit the 1-cup button, and less than 1 shot of espresso comes out before it beeps several times, and the lights flash on and off repeatedly. It seems angry when it does this. I wait a couple minutes, then try again, and finally get a full shot of espresso. What am I doing wrong? I'm just trying to get a double-shot, but it now barely gives me 1. I even replaced the little metal cup thing with a new one, no change. I switched to pre-ground espresso in case it was the grind being too fine, but still not better. Did I buy a bad machine???
My coffee and filter are in place, the water is in, the bottom gets very hot....but no coffee...
(More)
My coffee and filter are in place, the water is in, the bottom gets very hot....but no coffee brews/drips. I need coffee...help!!
