Question about iRobot Roomba Red 4100 Bagless Robotic Vacuum
Roomba brushes won't spin
My Rooma Red's brushes stopped turning. I've cleaned them, check to make sure they're still square and said a few choice words.
help
  • Anonymous Jan 17, 2009
    I have the same problem where can i find pics to help me clean the rear.
    thank you
I had this problem with my Roomba Discovery. I ran across your question while searching for an answer. My main symptoms were, Roomba hesitated a lot, and the dust bin did not fill. I had plenty of hair wrapped around the brushes and against the filter.
I just finished taking my Roomba apart. I found the motor drive shaft had a LOT of hair wrapped around it and it had climkbed into my gearbox. I took that apart and cleaned all the hair out of the gearbox. My Roomba is back to normal now, filling the dust bin.
Posted on Dec 29, 2008
My Roomba 530 is as clean as a whistle but after about 1 minute it stops and says clean my brushes. I dod see that the brushes do turn and I see and feel the fan going what else can I check
Check the spinning brush, take it loose with a phillips screw driver. Check the pair of soft tubular brushes, the ends can clog up. Check the small third wheel, it can clog on it's axle which pulls out for easy cleaning.
Jan 23, 2017 | Roomba Vacuums
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
It starts and for a few seconds and then stops The battery is fine
Is the charging ase turned on and is the dust container emptied? Any obstructions?
Apr 11, 2010 | Roomba Robotic Floor Bagless Vacuum
Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
  1. Power off the Roomba.
  2. Remove the dirt bin.
  3. Place the robot upside down on a flat, padded surface.
  4. Check for any dust or dirt obstructing the Cliff Sensors (with Roomba upside down, the sensors are located in the four rectangular areas just inside the edge of the front bumper).
  5. Next, press the front bumper in to make sure it springs back.
  6. Make sure both yellow brush caps are installed correctly
  7. Make sure the main brush and the flapper brush each have a yellow bearing installed correctly.
Mar 26, 2010 | Roomba Robotic Floor Bagless Vacuum
Irobot roomba brush only spins on hardwood/tile. brush stops when it hits carpet. motor prob's? fix?
Remove and clean the yellow bearing on each brush, then reinstall them. Run the Roomba and ensure that the brushes do turn on hardwood, then test it again on carpet. If the brushes still stop turning on the rug, call customer support at 1-877-855-8593. They'll be able to determine your warranty status and discuss your options.
Aug 05, 2009 | iRobot Roomba 4300 Robotic Vacuum
Roomba keeps saying clean brushes yet are clean!
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Roomba wheel -- stuck
I had a similar problem, I just took my Roomba Red apart and put it back together about four times before I fixed it.  In my case it turned out to be a dirty sensor, fixed as described at
http://mysteryroad.blogs.com/photos/roomba_gallery/xintroroomba_3549.html
Before you open it up I recommend following the diagnostic tests to see if its a physical problem (bad motor belt, hair stuck around the wheel) or a sensor problem (dirt makes Roomba think it is stuck when it isn't).  If you follow the diagnostics one of them will move the Roomba wheels while ignoring the sensors; if the wheels move fine then you probably have a sensor problem.
http://www.roombareview.com/swiftracer/roombareddiagnosticsmode.shtml
-- Ben www.benzado.com
Jul 10, 2008 | Roomba Robotic Floor Bagless Vacuum
Repairing stuck wheel/Roomba Discovery
just learning, but sounds like the one that doesn't spin freely is the good one.
The other may have a broken belt.
http://www.roombareview.com/swiftracer/roombabeltreplacement.shtml
Roomba Stops
I just fixed mine by cleaning the shaft that the spinning brushes is on. I used an eyeglass screw driver to tke out the screw. it is running great now. I didn't realize my brushes werent spinning at the time of my post. Cleaning this part seemed to have fixed the problem.
Jun 03, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba turning off after 30 sec.
I was having the same problem. Roomba would run for 30 seconds and then stop. I tried everything -- then I took the small rubber brush out and removed the small nut at the end. It was packed with dust to the point that it could not turn easily. I cleaned it out and now it is working like a champ. I think the automatic shut down was just a sign that there was too much strain to turn the brushes.
Nov 27, 2007 | Roomba Robotic Floor Bagless Vacuum
iRobot Roomba Red 4100 Bagless Robotic Vacuum Logo
1,849 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
