Question about Microwave Ovens
Frigidaire fm148, both surface lights went out, but one was still good. replaced both lights with no results. The read out on the touch pad shows that the lights are working,but no illumination. Everything else working as expected.
    Master:
  • 638 Answers
While removing the screws of old light for replacing it with new the connections could be loose. check that first.
if its perfect than the problem is with main circuit board.
We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board.
For safety, disassembly and other info see http://tinyurl.com/yzjozk
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 28, 2008
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
My Microwave mysteriously starts for no reason and I cannot stop it unless I open the door
This is due to fault in the touch pad or the front control unit. There is dirt or moisture which triggers the start to function on the processor board. You need to remove the front panel and remove the touch pad /controls, try and dry using a dryer to warm. If there is no result the pads must be replaced. Also check for clogging of insects within the board which can trigger the start function or malfunction. remove and clean the board.
Jan 25, 2013 | Microwave Ovens
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
I was washing the Frigidaire microwave today, and now the buttons do not work. I see the time, and the light turns on; I unplugged the microwave and plugged it back again, and the buttons still do not...
Some moisture has probably made its way into the touch pad. You might try heating it a little with a blow dryer on low heat to try and dry up the moisture inside the touch pad or just unplug it for a day or so and see if it will dry up on its own. If it does not start working the touch pad would need to be replaced. Hope that helps.
Aug 30, 2011 | Frigidaire Microwave Ovens
THE KEY PAD QUICK WORKING. I HAVE REPLACED THE CONTROL BOARD BUT THEY STILL DO NOT WORK.
Hello, Thank You for using FixYa. I will be helping you today.If the buttons are not working replace the touch membrane. I would list the part number but you didnt give full model number.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Frigidaire PLMB209DC Microwave Oven
Touchpad is not working
Hello :
If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
Place window mesh over vent to keep insects out.
good luck .
please rate !
Mar 29, 2010 | GE Microwave Ovens
Control panel went off and hence it stopped working
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Frigidaire / Whirlpool installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 26, 2008 | Frigidaire PLMV169DC Microwave Oven
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Crisp display
yes, it does indicates there is a bigger problem It has run a self- checking program and displayed the error before calling help see in this model page there is a manual of the oven, check last pages if they help u if no still there are instructions what to do and who to connect read it well before calling it will save u more then a couple of $$$ good luck windman
Jan 17, 2006 | KitchenAid KBMC140H Convection Microwave...
Microwave Ovens Logo
63 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
