Question about Compaq Presario 700 470024-192 Notebook
Sound i have problem with sound i can't use mic and i can't talking by messenger i hope there some seluation if it possible help me pls thanks
  • 46 Answers
Hello Jassimin:
First you have to isolate the problem, you need to check if it's a problem with your hardware of your computer or if it's a problem withn your software.
First try using Microsoft Sound Recorder (usually it's located at Start -> Accessories -> Multimedia -> sound recorder.
Try recording anything using that, If you can do it; then probably it will a problem with your software MSN, try re-isntalling it.
If you cannot record anything, of if you get a message that there's no recording device; then it's something related with the microphone or the driver for the mic....In case you need the driver, please let us know the model number of your laptop (usually it's a the bottom ....
good luck
Posted on Jun 28, 2008
Microphone muffled
Try to talk with your lips touching the mic . If there is any improvement open the mic housing very carefully and bring the capsule as near as possible to the top part of the housing .
hope this helps.
Sep 08, 2012 | Logitech USB Desktop Consumer Microphone
I am not able to turn the inbuilt microphone on in Acer aspire 4736Z while on a videocall with my friend on skype or yahoo msgnr. i can hear her but she cant hear me at all. also theres a constant...
It will be good to test the microphone in the sound recorder to see if the driversa re supporting , if not reinstall the drivers or choose to set to a earlier restore point.
If the mic is working good it must be seen if the Skype and messenger has some conflicts therby disabling the mic.
So take chance and uninstall the messenger to try if the fault clears.If not uninstall the skype and check with the messenger.
If the mic is not working at all it can be a hardware issue , a fault of the mic.
Sep 30, 2010 | Acer Aspire 4520-5582 Notebook
Toshiba Satellite L505-S5966 internal built-in
have u only used messenger to test your mic? try other applications like a voice recorder, and see if yer mic will pick up there. if it does, then mabey u have the wrong version of messenger like if u have 32 bit or 64 bit version of windows. if it doesnt work, then you have a driver error and u can go into start>control panel>device manager>and other computers are different, but i'd go into imaging devices cuz my cam and mic are a full set of drivers together but see if you have a microphone on there. if not, then look at wot u can see that has any possible relation to a microphone, and select "update driver software" and it'll go online for ya and see if the drivers are up to date. and if its not the driver, then its your mic itself, and hopefully your under warranty, or if not, then just pay some money and get it fixed.
Dec 08, 2009 | Toshiba Satellite L505-S5966 Notebook
Hp compaq 110 , mic is not working on windows messenger ,its a built in mic ,, it works when im not on messenger. and i have tried the setting on windows messenger but it cant pick up the sound.
It may not be a microphone issue, but a messenger version used by either you or your contact.
I got the same problem before.
One of my contacts couldn't hear me while using messenger, but I could talk to "others" on my same messenger.
Once that contact upgrade its messenger the problem was solved..!
Please don't forget to rate this answer if it helps
Oct 28, 2009 | Computers & Internet
I cannot get voice in yahoo messenger and yahelite on my asus pc with windows vista i can hear people but cannot talk back to them....the microphone is ok and the pc is brand new
firstly check ur headphone. is it ok. if ok then go to sound system on ur computer and correction mic sound and select output device is stero headphone. if everything ok then check voice sound system in ur yahoo messenger. thanks
Jul 18, 2009 | Computers & Internet
Microphone not working Need help please
Make sure it's plugged into the Pink Jack on the computer. You probably already know that, but if not hope this helps. Bud
Jul 19, 2008 | Computers & Internet
Why my mic dosnt work on yahoo chat
zzzdisk
It is a general problem, you have to see on control panel, and see if the correct drivers for the particular modem is well installed. Also check your conection again, (settings) for your TCP/IP configuration, and dialup? set up.
check your drivers for your modem too, and if you set up correctly the Messenger, on setup the mic,cam, and sound.
good luck
Nov 26, 2007 | Audio Players & Recorders
Push to talk problem
If indeed radio #1 has a mic problem, this may be confirmed by trying an external speaker/microphone plugged into the accessory jack. If still a no, then its not the mic but possibly the modulator circuitry. If there is transmit audio with the external mic and hence internal mic is defective, the unit would have to be pried open and the defective component replaced. The internal mic is normally an electrofet 2-3 terminal soldered to a shielded wire and physically attached to the front plate.
Alternately, another possibility is that radio #2 has its Interference Eliminator Code enabled/activated. This is indicated by the presence of small sized digits on the top right of display. If this is the case and no similar digits are displayed in radio #1, then radio #2 will not allow any received transmission to be heard. Along the same line of reasoning, if the code is activated on both radios signified by the presence of the 2 small digits, and radio #1 has a problem with its CTCSS (code) generator, then it would also prevent reception of radio #2. A way to verify this is by deactivating/disabling the Interference Eliminator Codes on both radios.
On certain occasion, it is also possible that radio #2 has a defective speaker. You should be able to verify this by plugging in an external speaker to the accessory jack of radio #2.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 09, 2007 | Motorola Talkabout FRS 250 (14 Channels)...
Microphone and speaker problems
Do a virus scan first FREE ANTI VIRUS Try here its free http://www.kaspersky.com/kos/eng/partner... If you can not access or open IE right click in and select Properties then set the homepage to Blank! SOUND RECORDING\MIC ON USB CAMERA In Windows XP Select the proper Audio Input Device (Sound Recording) under the Audio Tab in Sounds and Audio Devices in Control panel. Usually it is name after the USB Camera. CONNECTION Check your connections on Rear part of your PC. Lime is for Sound Out usually a speaker, Pink is for Mic, Blue for Audio Input. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester.
Sep 20, 2007 | Audio Players & Recorders
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
