FixYa.com
Tags:
Refrigerators
Generic problem for all Refrigerators
Auto defrost failure fo Majic
posted by rogerancarol on Jun 28, 2008
auto defrost failure fo Majic Chef refriderator model MCBR 1000W
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 29, 2008
Thanks for Trying (70)
mikedurland
Rank:Guru Guru
Rating: 89%, 258 votes
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Comment by mikedurland, posted on Jul 06, 2008
  • none of my free suggestions have helped you at all?
  •  if you fell  the issue with the machine is something else let me know, i will try to help you figure it out.
Mike
Rating Locked! (?) rogerancarol has rated this solution as Thanks for Trying
This Problem Also Relates To: GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator GE GSL25JFPBS Side by Side Refrigerator GE GSS20IEM Side by Side Refrigerator GE GSS22JFMWW Side by Side Refrigerator GE Profile Arctica Stainless Steel Top Freezer Refrigerator GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... GE Energy Star PDS22SIS Stainless Steel Bottom Freezer Refrigerator
Can you Help with these Refrigerators problems?
Refrigerators
FF200EP Fridge Freezer - water
FF200EP Fridge Freezer - water... Answer This...
Refrigerators
westinghouse frostfree fridge...
westinghouse frostfree fridge... Answer This...
Refrigerators
I want to register my
I want to register my new... Answer This...
Maytag MFI2568A Side by Side French Door...
maytag refrigerator sid by side...
the alarm keeps beeping and the... Answer This...
Kenmore 53082 / 53084 Side by Side...
leaking water
we have a side by side... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
