Question about Kodak EasyShare Z1275 Digital Camera
EASYSHARE Z1275 Digital Camera
My daughter dropped my camera, (EASYSHARE Z1275 Digital Camera) not a hard drop at all by the way, and now it shuts itself off every time I snap a picture. When you try to focus in on images through the viewfinder they look like cave stalagmites. Distorted. Then when you snap it, the camera shuts down with the lens still out. It will come back on if you take the batteries out and put them back in, but it does the same thing when you try to take a picture each time.
KODAK EASYSHARE Z1275 is a peice of ****
Posted on Aug 13, 2008
I have easyshare Z1275 and once I printed pictures on my printer, thezoom lense will not close down and I can't turn it on, even if the battery is removed, it won't shut down. Help. I love this camera,
Camera does not
turn on.
■ Install new batteries (see page 1).
■ Charge rechargeable batteries.
Camera does not
turn off.
■ Remove the battery, then reinsert or replace it. If the camera still does
not function, visit www.kodak.com/go/z1275support,
www.kodak.com/go/z1285support and select Interactive
Troubleshooting & Repairs.
Jun 15, 2010 | Kodak EasyShare Z1275 Digital Camera
My Kodak v1253 has the error "High Camera Temperature" then shuts itself down. Is this a battery problem?
Assuming you have the battery and memory card in the camera, turn the camera on by pressing down the two buttons on the top left of the camera together at the same time.
Apr 08, 2010 | Kodak EasyShare Z1275 Digital Camera
My kodak z1275 wont turn on
first check wether those batteries are getting charged solution is to replace the batteries as you might nave not used the camers from quite long time
Jun 10, 2009 | Kodak EasyShare Z1275 Digital Camera
I dropped my camera and now its broke how do i fix it i drop my z1275 camera and now the lens wont go back in.
if you really want to fix this problem simply just open the screws little bit and you can yourself adjust the lenses
but i will suggest you to take the camera to the service center
Jun 01, 2009 | Kodak EasyShare Z1275 Digital Camera
CAMERA TURNS ON FOR A SPLIT SECOND THEN SHUTS OFF
My Z1275 was off with the lens open. When I turned it on, the lens moved a little, the screen came on
for an instant, and then the camera off.
Here is what I did to "fix" it.
I turned it on and helped the lens (gently) close while it was moving. It closed and the camera came on.
It must have been dropped and slightly bent in such a way where the lens could not close.
Good Luck!
Dec 29, 2008 | Kodak EasyShare Z1275 Digital Camera
EasyShare C875 dropped, won't focus
yes i'm afraid it is a lost cause as the camera has now suffered from shock damage sorry!!!!!
kind regards and please don't forget to rate us
Dec 09, 2008 | Kodak EasyShare C875 Digital Camera
Lens stuck open after dropping.
Sounds like your lens is out of alignment. Added to that something w/ the screen is affected by the lens. Safest way is to have a technician check it out. A short cut I take is to look at the lens carefully and see if there is something loose or how mis-aligned is the lens. Sometimes a slight nudge will get it working properly. But whether it starts to work or not, the lens is already misaligned and you may still have a problem taking clear pictures. So even with my short cut, I'd still suggest you bring it in for repairs. It's really not a good idea to do short cuts unless you have a budget problem. Take care of your camera and keep the strap around your neck at all times so you don't drop it again.
Jul 16, 2008 | Kodak EasyShare Z1275 Digital Camera
Kodak EasyShare Z1275 Digital Camera software
Though I'm not sure how to solve this problem, I don't recommend using the program for downloading pictures at all, it's unecessary and slower. Without it, you can treat your camera the same as any other USB drive - open the camera drive as you do any other folder, and drag/drop or copy/paste picture files off of it.
Nov 06, 2007 | Kodak EasyShare CX6330 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
184 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
