DeLonghi 6707E Oil Filled Radiator Heater Logo
Posted on Dec 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have used my Delonghi about 4 times now, but last night it was leaking an odor that smelled poisonous. I woke up because my fire and carbon monixide alarm beeped and I noticed this horrible smell. I dont know what it was but it was toxic so I turned it off and the odor went away. Have you heard of this before?
Anonymous
Level 3:
  • DeLonghi Master 43,501 Answers
  • Posted on Jan 12, 2011
Anonymous
DeLonghi Master
Level 3:
Answers
43501
Questions
0
Helped
10844995
Points
101584
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman10
Fumes smell from gas heater
Open a window fast, carbon monoxide poisoning could cause death, and that has no smell ! are you getting headaches?? Contact manufacturer, they usually have a good warrenty. You must vent out the exhaust!!
3helpful
2answers
I smell gas
Sound like it could be quite a few things. Off the top of my head I would check that the car is firing on all cylinders. If one has gone down you will have fuel travelling along the exhaust pipe, which could explain the smell. If you have lost a cylinder it will be as rough as a badgers B*M, and you will get rubbish mpg. Check if you can smell fuel from the exhaust pipe (Not while the car is running I don't want you to get carbon monoxide poisoning), just give it a quick start and a few revs first. If it is or anyway If you take the plugs out one at a time look at them to see if they are wet and smell of fuel, (After a quick start and a rev). Check your air filter as well you could even take it out and see how it runs (Not for long just a quick blast) see how you go with that.
Good Luck
Gas smell when using and not using
follow this steps and fix it. God bless you
f the pilot light on your stove goes out, natural gas may build up in your stove. If your pilot light has gone out, open the kitchen windows and doors for 15 minutes to let the gas dissipate safely then relight the pilot light. Do not relight the pilot light immediately -- striking a match could cause an explosion.
Gas Leak
  • If you can smell the sulfur-like or rotten egg smell of gas, there may be a gas leak inside or outside your home. You might also hear a hissing sound coming from the stove or another appliance or from a pipeline. Outside gas leaks may kill or stunt nearby vegetation. Signs of carbon monoxide poisoning include nausea, dizziness, fatigue and other flu-like symptoms.
f you still smell gas after relighting the pilot light, don't hesitate. Leave your home, along with the rest of your family and pets, then call your utility company or 911 from a safe location. Leave the doors and windows open behind you, especially if the odor is strong or you can hear the hissing of a gas leak. Do not turn appliances or lights on or off or use a phone in your home. Do not strike a match or use a lighter, either. Prevention
Read more: http://www.ehow.com/info_12193884_smell-gas-house-still-lingering-after-shut-off-stove.html#ixzz2aT2VTMtc
2answers
I just had it installed and smell gas. if it says unvented , does it need vented or am i ok. im 73 yrs old and dont know much about gas heaters
An un-vented heater should never smell like raw gas, you may get an odor of combustion by-products but never raw gas. If you are getting the raw gas smell you either have a gas leak or incomplete combustion. Always follow manufacturers operation instructions that state "open window 1/4" to allow combustion air" If the unit is brand new, you will get an odor for 20 minutes or so of oils burning off of the heater but that smell should go away. Do you have a Carbon monoxide detector in the house? You should!
Twice in the last year, I have had a gas smell come from my Goodman furnace. In this last case, the smell of gas came through the duct work. There was not smell in or around the furnac itself. Some how...
Did the tech check to see that the heat exchanger does not have a hole of a crack in it...I have seen this and it is more common than you think....Make sure you get to the bottom of this as there is the danger of carbon monoxide poisoning...I would suggest to not use furnace till you figure it out
1helpful
Last night we woke up to a very full room of heavy plastic smoke, The control panel on our Delonghi heater was burning. The heater was set on 3 and we were only useing The lower setting. Our daughter has...
You are lucky to be writing this, plastic fumes can be poison to humans and animals. It appears you had it in a safe area as the house did not catch on fire. I would not use the other unit but keep it. Contact the manufacturer and see what they have to say. If they want the unit back contact a lawyer before sending back. You may also ask them to cover the cost of cleanup of your home.
Good Luck,
Gil
1helpful
Awful odor when 1st open car door after setting for 15 minutes
You should have the computer scanned for fault codes. Many times the engine is running to rich and causes the catalytic converter to overheat. This will cause a rotten egg type smell.
Can you post back with a description of the odor? Does it smell like gasoline or oil?
It also could be a carbon monoxide smell that could be very dangerous, it is a possibility that exhaust fumes are entering the cabin of the vehicle, this could lead to poisoning.
Let me know what you find and if I can assist further. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
2answers
Burning smell from AC Unit
http://www.hannabery.com/faq14.shtml
"Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
We will go through each of the five categories and list the possible causes and things to check.
1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
But this odor problem is almost never due to a problem with your equipment.
Final Tips:
Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
