1995 Ford F150 Styleside Regular Cab Logo
Posted on Dec 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I pushed on my parking brake and something snapped, resulting in my brake pedal pressed to the firewall,when i pulled the release latch it would not come back up,i pulled the pedal up manually but now i have no parking brake at all,the pedal is limp. upon a quick inspection it doesn't appear that the brake cable has snapped, however i noted the cable that runs allong the frame,to the rear tires is now slack. i have a 1995 Ford F150 XL pickup truck (regular cab) if you could tell me how to troubleshoot and fix this problem i would greatly appreciate it Thank You.
Anonymous
Level 3:
Brigadier General:
  • Master 3,911 Answers
  • Posted on Dec 08, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
3911
Questions
Helped
984280
Points
10712
If you know someone with a lift, get it up in the air and take a good look. it should be immediately obvious which end or which cable has failed. i think you will find there are two cables in the rear which meet one coming from the front at a central threaded rod adjuster. common for them to become rusted and break at pivot points, swivels, backing plates. it is not unknown for an independent muffler shop to put your vehicle up on a lift and let you take a quick look for 10 bucks or so.
How too release the emergency brake foot pedal when the cable is broken?
About 73,400 results (0.87 seconds) Search Results
    Parking brake release cable snaps - Chevy Avalanche Fan Club of ...
    chevyavalanchefanclub.com > ... > Problems: Brakes
    24 posts - ‎16 authors
    Went to release the parking brake on my 04 and the cable snapped. ... More like the end cap coming of the cable that attaches to the foot pedal. ..... Then I released the parking brake, pulled out the broken release cable/handle assembly, ...
    How To Install Repair Replace Parking Brake Release ...
    ? 5:54
    https://www.youtube.com/watch?v=qx0oGfV62NQ
    Jun 23, 2011 - Uploaded by 1A Auto Parts
    How To Install Repair Replace Parking Brake Release CableHandle ... or replace a broken or worn out parking brake release cable handle.
    Emergency Brake Pedal Assembly & Stuck Brake Cable ...
    ? 10:13
    https://www.youtube.com/watch?v=0jYfvthBzhU
    Apr 17, 2014 - Uploaded by corgLLC
    Emergency (Parking) Brake Pedal Assembly & Stuck Emergency (Parking) Rear Brake Cable The emergency ...
    E-Brake Cable Broken? Stuck Emergency Brake... Help Please ' Chevy ...
    www.tahoeyukonforum.com > ... > Engine & Drivetrain
2answers
Why won't 98 Buick century shift into any gear?
is it a linkage issue? if the shift lever is working and you can feel the detents, check your fluid make sure it is full and clean, if not you could have internal issues with the trans
Emergency brake stuck to the floor
if your mechanical minded you can release it with a flat blade screw driver but it will be tight ,you need to release the tention by pushing hard on the pedal ( or use 2 people) and you will see how the ratchet locks the pedal pry up on it while you slowly lift the pedal up .
How do u release the emergency brake in a pacifica
Press the parking brake pedal down further, keep pressure on it then pull the release handle out and hold it out then let you foot off the pedal.
How do I remove the Brake Pedal Position Sensor on a 2003 Lincon Aviator in order to replace it?
Follow the Brake pedal back towards the firewall you will come to see it as it presses against the pedals metal bracket it just snaps in and snaps out some had an adjustment on them maybe you will get lucky
My cable snapped on my parking brake....
snapped cable released brake, handle is stuck behind panel
2helpful
With car running The shift leaver willnot come out of park
When pressing the brake pedal, you should hear a click at the shifter, as the shift-lock mechanism is releasing the lock on the shifter. If the sound isn't heard, there may be a defective shift lock solenoid (which may require replacing entire shifter assembly, depending upon model). Otherwise you may need to remove access cover at top of shifter to insert a screwdriver to push down on the bypass latch so you can shift out of park. You will also need to push down on latch to go back to park.
How do you take the parking brake pedal assembly off a 1999 Silverado Chevy? Are there three or two bolts? What has happened is the cable broke or fell off the parking brake assembly. It will not come back...
1. Remove the electrical junction box that is monuted on the lower firewall to the right of the pedal assembly.
2. There is a small cable that runs from the parking brake release lever to the pedal assembly. Use the release lever to remove the tension on the cable, then inclip the cable from the top part of the pedal assembly.
3. Remove the three 1/2" nuts holding the pedal assembly in place. You will have removed one already to take out the electrical juntion box. THe other two are on the top of the pedal assembly, holding it to the side of the vehicle.
4. Under the vehicle, disconnect the front of the parking brake cable from the rear section of the cable. You will have to pul this cable up through the floorboards. Remove the clamp that holds it to the frame and pass it through so it is ready to go up thru the floorboard.
5. Remove the pedal assembly from the interior wall of the vehicle. Pull the rubber grommet and cable up thru the floorboard.
5.
2helpful
2answers
Parking brake cable is broketn, how to release the break>
Unless the brake cable is caught on something under your truck then they are already released.When you push the pedal down you pull on the cable engauging the P brakes,when you release the bakes you take tension off.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
