Question about Saeco Vienna De Luxe Espresso Machine
Water leak My machine is 6 years old and we just started using it after a two year lapse. It makes coffee fine but it leaks water in between the tank and machine. The tank valve works fine, but it slowly empties as it sits on the machine.
  • 515 Answers
You have to replace the gasket where the water tank goes in to the machine.
Posted on Jul 10, 2008
Our delonghi magnific was cleaned using delonghe descaler and began leaking almost immediately, we replaced the water resevour but this has not improved matters, any thoughts? Nic
i had the exact same problem. My machine was working perfectly and have had it for about 5 years. I descaled usnig the solution that was sold to me by DeLonghi Customer Service, followed the instructions perfectly and after the cleaning/descaling process was complete, it started leaking from the resevoir side and possibly underneath. The water tank seal seems to be fine and cannot locate the source of the water without taking the machine apart. I also hear steam coming from somewhere for about 5 min after making a cup of coffee. If you find a solution, please email me at steve_hadeed@yahoo.com. Thanks
Aug 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Water leaks from the bottom of the odea go when brewing. We have soaked the brew group, tried to lube every spot we could think of, and still no luck. Machine is 1 and 1/2 years old. thanks.
If it's from the left side of the machine, probably the tap valve seals are leaking. If alot of water leak out without any coffee from the spout, then the hoses rupture or boiler leakage inside the machine.
Jun 18, 2010 | Saeco Odea Go
Our 7 year old Saeco Magic Delux has started to leak water when we fill the tank. It runs out of the bottom of the tank and down the side. Happens about 20% of the time. Is it worth having a 7 year old one...
If I understand well the problem is only with tanks valve which means the spring have become more soft and stays a litle open so you have water leak. It maybe because some scale or dirt keep it open some time.
In order to decide if it wise to fix it or not the answer is simple if you have a good coffee result in cup which means that the grinder grinds good, presure pump work good and boiler heat up ok then you will only need to complete descale the machine and replace only small cheap parts and you will have a very good machine again for some more years. Remember a brand new machine will do the same espresso like yours.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Magic De Luxe Espresso Machine
My bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Oct 24, 2009 | Bunn NHB Coffee Maker
My Brunn coffee maker is leaking from the bottom also.
I have the same problem and I took the coffee maker apart to find out why. The fitting for the hold in the black pastic that the water flows through to get into the stainless steel tank may not have a tight fitting with the plastic and that's where I had water leakage. I used some silicone sealant to fix the leak and the water stopped leaking!
Sep 28, 2009 | Bunn 10 Cup Home Coffee Brewer
Leaking from top of water tank
It sounds like a broken seal/gasket. If you will get the model and date code and contact customer service, we will be able to properly assist you in resolving this problem. The machine carries a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced cost.
Aug 29, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Apr 29, 2009 | Bunn 10 Cup Home Coffee Brewer
Won't get all water out
I just fixed it! I took the bottom off and snipped the wire ties so that I could remove the heating element. There are 2 clear tubes about 1/2" thick attached to each side. The one on the left had some coffee beans jammed inside from when my 6 year old tried to make coffee. I removed the tube and cleaned it out thoroughly and assembled the coffee maker back together and it brews perfectly now. The leaking has also stopped. Hope this helps someone.
Nov 10, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Not building pressue
Water damage to the flow meter can cause the machine to not function at all. We have seen water leaking from the water tank leaks right on the flow meter and stops the machine from heating and contining its start up proceedure.
Espresso machine Sales and Service.
www.CeriniCoffee.com
johnny@cerinicoffee.com
Sep 04, 2008 | Pasquini Livia 90 Espresso Machine
Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Jun 26, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
99 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
