Question about Dell Dimension 4600 PC Desktop
Wireless card for dell 4600c
What kind of card do I need to get and is it easy it install? WHere would I find instructions? I goggled this and got you guys
  • 46 Answers
Hello cmprice.
You can get any USB wireless card; I recommend you Linksys or Dlink.
Remember that the wireless card will work only if you have any wireless modem/router at home.. ok?
Posted on Jun 28, 2008
Identify correct network card for dell xps 420
You can buy any network card and install it to your computer. All you need to figure out is what type you want to get,
PCI card or USB
Wired or Wireless
Nov 29, 2012 | Dell Ethernet Card Network Adapter
I need to replace a network card in my Dell Dimension 4600. I already have the new card. It came w/ a driver CD but no other instructions. What is the proper procedure to replace this and have the PC...
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please clcik on the below link that has the steps for the physical replacement of the card
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/parts.htm#1116421
once done you need to install the drivers for the lan card and then you should be able to get online
let me know in case you have any queries
Nov 22, 2010 | Dell Dimension 4600C PC Desktop
No output to video monitor
I would suggest that you can use PowerColor ATi Radeon 9550 SE 128MB 64bit DDR AGP 8X Low Profile Video Card which works fine with Dell Dimension 4600c. Please write back to me or place a comment if it works for you or if you need any further assistance.
Good Luck.
Mar 31, 2010 | Dell Dimension 4600 PC Desktop
I need printed instructions on how to install Dell Dimension 4600c power supply. I ordered the part but it came with no instructions.
Power Supply Removing the Power Supply caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in your Owner's Manual or Product Information Guide. caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before removing the cover.
  1. Follow the procedures in "Before You Begin."
  2. Remove the fan assembly.
  3. Disconnect the AC power cable from the AC power connector on the back of the power supply.
  4. Unplug the DC power cables from the drives and system board.
  5. Remove the four screws that secure the power supply to the back of the computer.
OR
As you add more devices to your Dell Dimension 4600 desktop, it is important to ensure there is enough electrical power being fed to the components. While the 250 Watt power supply that comes standard with the Dell Dimension 4600 is acceptable at stock settings, it is almost certainly not capable of providing power for many more devices such as graphics cardsmag-glass_10x10.gif and multiple hard drives. If you add such devices, you also should upgrade your Dell Dimension 4600 power supply.
Aug 28, 2009 | Dell Dimension 4600C PC Desktop
Questions about replacing ethernet card on my Dell desktop
Any ethernet card will work fine. Just be sure it's the fit's the correct slot. You probably have a "white" slot which is a pci slot. If it's a longer "black" slot then it's isa. More than likely it came from a pci slot. Before you buy one, confirm the type of slot. In additon, before installing it go to control panel and system settings, hardware, device manager and remove the old one by right clicking it and select delete or remove. Shut down the computer follow instructions for new card.
Probably will have to install the drivers first then shut down and install the new card. Good Luck.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
My network card got damaged during a storm. Dell desktop 4600c
If you don't want to wait until Dell send you back one, just go to Best Buy or any other computer store and buy a small-factor PCI network card, I assume you have an free PCI slot available, if you have a wireless router then it maybe be easy to get an external USB-based wireless network card.
Mar 18, 2009 | Dell Dimension 4600 PC Desktop
Upgrade wireless to 802.11n on this machine
Well, the easy way to connect to your router is not to replace the card, thats overkill!
Do it the easy way and buy a wireless USB adapter insted! :) to be 100% sure that it wont give u any truble is to buy an USB adapter from the same manufacture as your router.
That will solve all your problems whit a low cost:)
Good luck to you!
Please take a minute and vote
Nic
Jan 29, 2009 | Dell Inspiron 700M Notebook
Wirelesscard for 4600c dell
IF you already have a wireless router, than any pci wireless card will install in your dell. the instruction pamphlet is simple to follow.
Likewise Any USB wireless adaptor will pplug to any vacant usb port and connect, the instruction pamphlet is simple to follow.
Jun 28, 2008 | Dell Dimension 4600 PC Desktop
Dell Inspiron 1520
it'll not fit since your laptop needs an expresscard.
here are the list of the wireless cards that you can get:
Dell Wireless 1390 802.11g Mini Card Wireless Dell Wireless 1490 802.11a/g Mini Card Wireless Dell Wireless 1505 Wireless-N Mini Card Intel Pro/Wireless 3945 802.11 a/b/g Mini Card Wireless Intel 4965AGN Wireless-N Mini Card Dell Wireless 5510 HSDPA ExpressCard34 Dell Wireless 5520 HSDPA Dell Wireless 5720 EVDO or a Linksys Wec600n Wireless-N Expresscard Adapter
Jun 04, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
My wireless card is Dell TrueMobile 1150 Series Wireless LAN Mini PCI Card.when i connect my laptop that i ve already added to my wireless network (workgroup),it keep telling me that wireless connection...
Hi, Sometimes the built-in Windows Wireless Configuration Utility fouls up. You may have to install and use the Client Manager Application for the TrueMobile 1150 Wireless Network Card. This is better explained at Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Dell Dimension 4600 PC Desktop Logo
827 people viewed this question
Alun Cox
