Question about Dell Dimension 4600 PC Desktop
Wirelesscard for 4600c dell
What do you buy to do this and is it hard to install? Do you ave instructions?
  • cmprice888 Jun 28, 2008
    trying to send you a digg but not sure what to call you in the search for friends lol
  • 550 Answers
IF you already have a wireless router, than any pci wireless card will install in your dell. the instruction pamphlet is simple to follow.
Likewise Any USB wireless adaptor will pplug to any vacant usb port and connect, the instruction pamphlet is simple to follow.
Posted on Jun 28, 2008
Dell Demension 4600C
Buy a genuine Dell. The part number should be C9664 or another compatible SATA cable. You can find it here:
Dell C9664 - 17" SATA Cable for Hard Drive
These are pretty easy to find, if you cant afford that one, then buy a generic one on ebay.
Jun 24, 2012 | Computers & Internet
I lost the wire loop to hold down the heat chip what else can I use to replace the wire loop
http://support.dell.com/support/edocs/systems/dim4600c/sm/index.htm
I would use a piece of thin coat hanger, and bend the configuration I need.
http://support.dell.com/support/edocs/systems/dim4600c/sm/sffprcsr.htm
Make the configuration very close to the original green Securing Clip.
OR,
Go to Dell Spare Parts, and see if you can buy the Securing Clip.
Have the Serial Number written down. (S/N)
I didn't see it by searching with Dimension 4600C.
Not the best solution I'll admit. The only other thing is to search the internet for the clip, or buy another motherboard.
Regards,
joecoolvette
Sep 17, 2011 | Dell Dimension 4600C PC Desktop
Sombody gave to me old PC ,and I would like to Formate Hard Drive,and star all d from "0",Ike! I do not know how?
The drives can be formatted while you install new operating system. Boot the system with an Operating system disk and follow the instructions to format the hard drive and then install the new operating system.
Regards
Sherbaz
Aug 07, 2010 | Dell Dimension 4600C PC Desktop
I have a dell 4600c When i turn it on it powersup but no video
unplug your computer
Open the computer case up, reseat the memory by removing it and putting in one ,and starting the system,and check all power cables are connected. Do this to each memeory module that you have to test your memory.
IF that doesn't work remove , memory,hard drive cd/dvd drive,and printer etc.turn system on and if it does not beep then the motherboard is bad. The motherboad should beep to indicate that their is no memory.No beep equal no response from the motherboard. hope that helps.
Jan 10, 2010 | Dell Dimension™ 4600C PC Desktop
When plugged in, my dell 4600c will not start up, and the light on the front of the tower stays yellow. Is this a power supply issue, a hard drive issue or a motherboard issue?
The only real way to test all is to have a 2nd pc. You can even unplug the hard drive from the motherboard just to test the MB and power supply. The bios will still load without a hard drive attached to it.
Dec 21, 2009 | Dell Dimension 4600C PC Desktop
I need printed instructions on how to install Dell Dimension 4600c power supply. I ordered the part but it came with no instructions.
Power Supply Removing the Power Supply caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in your Owner's Manual or Product Information Guide. caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before removing the cover.
  1. Follow the procedures in "Before You Begin."
  2. Remove the fan assembly.
  3. Disconnect the AC power cable from the AC power connector on the back of the power supply.
  4. Unplug the DC power cables from the drives and system board.
  5. Remove the four screws that secure the power supply to the back of the computer.
OR
As you add more devices to your Dell Dimension 4600 desktop, it is important to ensure there is enough electrical power being fed to the components. While the 250 Watt power supply that comes standard with the Dell Dimension 4600 is acceptable at stock settings, it is almost certainly not capable of providing power for many more devices such as graphics cardsmag-glass_10x10.gif and multiple hard drives. If you add such devices, you also should upgrade your Dell Dimension 4600 power supply.
Aug 28, 2009 | Dell Dimension 4600C PC Desktop
Problem with Dell 4600C
Dimension 4600C driver
Developer: Dell
Version: 1.16.0
System: Windows XP,Windows 98,Windows ME,Windows 98 SE,Windows NT SP4,Windows Vista,Windows 2000 SP4,Windows 3.11,Windows NT SP3,Windows NT SP2,Windows 95,Windows NT,Windows 2000 SP2,Windows 2000
License: freeware
http://support.dell.com/support/downloads/index.aspx? here you will find your solution
Apr 14, 2009 | Dell Dimension 4600C PC Desktop
Wireless card for dell 4600c
Hello cmprice.
You can get any USB wireless card; I recommend you Linksys or Dlink.
Remember that the wireless card will work only if you have any wireless modem/router at home.. ok?
Jun 28, 2008 | Dell Dimension 4600 PC Desktop
External DVD Drives
Sorry to dissappoint you , but this not a possiblity.What you can to instead is copy the content of the DVD into a USB flash drive , and plugin the flash drive to your 4600c and install it from there.
A normal DVD reader writer drive , retails for not more that 65$ , so you can buy one two, more over local computer stores also keep refurbished drives, that you can get a good deal on.
Thanks
Mandeep
May 02, 2008 | Dell DVD-ROM for Dimension (6t903)...
Trouble removing case on Dell Dimension 4600c
Try this...
I work on these systems on a weekly basis and they can be very difficult to open. I would make sure that you have already removed the feet from the bottom and turn it so that the heavy side (technically right side up) will be facing the floor. Place the palm of each of your hands on each of the buttons and squeeze the system as hard as you can while holding the system maybe an inch or two off of the floor. The plastic buttons basically cover a metal release tab that is actually part of the frame. All of the clamshell type cases are tough to open because of this. Good luck.
Apr 24, 2008 | Dell Dimension 4600C PC Desktop
Dell Dimension 4600 PC Desktop Logo
106 people viewed this question
Alun Cox
