Question about Canon EOS-5D Digital Camera
Nothing works!!!!!!! I have been having problems with my 5D for some time now. The problems started with a piece of black felt on the sensor, which I noticed when reviewing my pics on the PC. I opend up the camera to check the sensor only to find that there was a piece of felt loose on the shutter. I sent the camera off to Camera Tech in South Africa for repairs. They are to my knowledge the only Canon appointed center in SA. The camera was repaired and sent back with a bill, as the camera was out of warranty by a few weeks or so. The bill was quite hefty and as usual I had to cough up for manufacturers' defects. I then noticed that after the repair, the scroll button was not working as a result of poor workmanship. The camera was sent back again. They fixed the scroll button and I thought this would be the end of my woes. I was wrong. The shutter started to jam up in mid-stride and make a sound as if there was either not enough power to drive it, or it was sticking. Sometimes it would stick completely and I would have to switch off the camera. This seems to happen mostly with my Canon 100mm lens. It has also happened with a flash connected when shooting TTl. I can't work out whether it is the lens or the TTl circuitry. The camera also gives me an error code when it jams up. I can't remember what the code is but I think it is 1, 4 or 99. I have cleaned the lens contacts. I now have a new problem which is that the image sharpness is lost. My Canon 100mm macro has always been pin sharp, even at 100% and even somtimes at 200%. This is not the case anymore. Someone at a local camera store told me this might be due to calibration or alignment of the sensor or something. All I can say is that I am now p*d off! With the kind of money we spend on our equipment these days we should not be subjected to such problems and when we are, the camera manufacturers should replace cameras without question! They are to quick to assume that we have done somthing to the equipment. All I can say is that my camera has its own climate controlled room and I look after it as if it were my child. It is stored in plastic, in a bag whith silica gel and is never exposed to moisture or dust. If I do have to take it out in bad weather it gets its own rain coat and duct tape. Someone please help me. I am on the verge of throwing this camera in the river, or taking up tennis. I hate tennis!
    Scholar:
  • 51 Answers
Hi
Really sorry to hear all this. The Canon 5D is a wonderful piece of kit and it is not good news to read your problem. It really does sound like the unit is having a multitude of problems. This could be resulting from electical failure inside the camera. From reading through your problems you have passed the Error 99 as well. Generally this would mean hardware faults of some sort. Solutions range from chaging the CF card to Batteries to cleaning the contacts. Clean the contact is one chief remedy and cause of the Error 99 after the 'quick' fixes.
I would say try this again but this time use a rubber on the end of the pencil. Be gentle and careful not to get any dirt into thedody of the camera. Clean all contacts on the 5D Body and on all the lenses. Should this not work it may well be the case that the camera has circuit board problems.
Below is a little guide to help out which was in response to Error 99 from Canon. Hope it does. Again sorry to hear of these troubles. Canon should be more Pro active in this competative world.
It may help some
of you isolate the problem before you post a comment/question.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Posted on Jul 15, 2008
The cd player is not sensing the cd .i can hear it try to start but keeps on saying no disk
try a different cd
try cleaning the cd
use an old cd and glue an eraser size piece of clean felt to it
make sure glue is dry and no hanging edges near felt
run cd with felt through player for five min to clean laser
try original cd still doesnt work open up and reset arm to
start position sometimes arm gets stuck.
replace cover try good cd again
still doesnt work maybe time to give up
Nov 15, 2016 | Televison & Video
Have a Canon 5d mark 2 . Was using it today all worked ok. Then it suddenly wouldn't review photos or bring up the menu . It shows black screen but when turned off it says the normal sensor cleaning
Hi Dear!
According to your problem note said wouldn't review photo or bring up the menu. You have to check all taken picture if there is blank, black, or corrupted picture file(cause won't able to see the image) are come from mirror box sequence control unit failing. At the beginning of this problem can not be noticeable, later it causes more and more blank image come out. However, if you don't have any blank image, then a loosen screw piece running around and touch circuitry in side could be serious. These two symptom are common and manufacturer's engineer design defect, but they won't tell you. Other then that you have no problem on your camera like last statement "when turned off it says sensor cleaning" This is camera's default setting that whenever you turn off camera will clean off sensor by itself.
Hope You Luck! A Professional Camera Clinic Guy!
Sometime there is defective main picture control process! But Canon won't say about it! At least you can try to convince them. (I want you shoot continuous a lot and video shooting) If it happen, then your main process board defect!
Apr 07, 2015 | Canon Cameras
Cagiva mito 125 evolution 2 will not start
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Cagiva Mito Starting problem
Cagiva mito wont start plz help
http://www.carlsalter.com/pdfs/Cagiva_mito_ev%201994.pdf
Cagiva MITO EURO2 125 2004 parts OEM Motorparts
http://www.cagiva.nl/media/owner_manuals/?tx_motomondo_pi4%5Bmodel%5D=&tx_motomondo_pi4%5Byear%5D=-1&tx_motomondo_pi4%5Bmanual%5D=
Sep 24, 2012 | Cagiva Mito 125 Motorcycles
Opel Vectra B model 1997 Gl 5d 1.6 wont fire up
Ok..for starters have you checked to make sure your getting fire to the plugs? Need to pull a plug wire off and check to make sure. If your getting fire then your problem lies in the fuel delivery system...if not then it would be in the ignition system...have you checked ALL of your fuses? Make sure that your fuel filter isn't plugged, and on the fuel rail you'll find a small port with schrader valve (similar to that on the tire)..you can turn the key to the run position and then push in on valve to see if your getting fuel to the rail..once you narrow it down to fuel delivery or ignition problems we can further narrow it down.
Mar 02, 2012 | Opel Vectra Cars & Trucks
Everything is working well except gaining access to the second screen. Pressing the advance key takes the first screen away then brings it back to the front, wihtout stopping at the second screen. The...
I still had both pieces of felt on mine and it failed like that. I took Ross' advice and just put a piece of electrical tape over both pieces of felt, a bit more than twice as big as what he suggested, and it worked fine. Easy access for me was to remove one of the back panels (4 screws) and then turn the unit on and then off when I saw the felt (in your case it may be where the felt used to be).
Thanks Ross. I found this thread by clicking on windledom in a different thread.
Sep 01, 2011 | Panasonic Panaboard KX-B530 Graphic Tablet
My bike is a cagiva mito evo 125 thieves tried to steal it and now it doesnt work what could be the problem? I've tried nothing to fix the problem yet
Hi, Doubleu120 and the usual suspects are:
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.
CAGIVA MITO 125
Free Cagiva Motorcycle Service Manuals for download
http://www.oemmotorparts.com/oem2.asp?M=Cagiva
Dec 18, 2010 | 2003 Cagiva Mito 125 Evoluzione
I get black streaks like the rest of you.. I
it's not the drum,it's the felt pieces that the drum rides on, there is felt on the back of drum and theres a felt piece on the front bulkhead, they could be worn leaving a space letting the clothing slip through hitting the black rollers or something is falling through the space hitting the clothes next time send the model number so i can look up your dryer,the model number is around the opening where you put the clothes into the dryer,open the door and look around the opening and you'll see a tag with model and serial number
Jan 22, 2010 | Kenmore 73952 Gas Dryer
The plastic piece came off of the inside of the  canon 5D camera I am borrowing. Can I get it back in somehow  without doing any damage to the sensor or any other parts?
yes but you need to be carefull. Put your body on a tripod and take achair in front of. In the menu, you find the cleaner wich will up the mirror..
Dec 07, 2008 | Canon EOS-5D Digital Camera
Black Ink Cartridge alignment problem
I have never heard of that happen before. I know if they have been refilled they lose there effectiveness causing leaks to happen.
Jun 14, 2008 | HP Photosmart 2710 All-In-One InkJet...
Konica Minolta Dynax 5D/Maxxum 5D turns itself off after first shoot
It sounds like that's the first black frame problem that is a fairly common defect with the cameras, so much so that Sony is repairing it for free, for more info, see:
http://ca.konicaminolta.com/information/20070202/01_en.html
then go to:
http://eservice.sony.com/webrma/web/index.do to set up for service.
Oct 18, 2007 | Konica Minolta Dynax 5D / Maxxum 5D...
Canon EOS-5D Digital Camera Logo
278 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
