Question about Singer 3116 Simple
3116 just goes in reverse
I used my 3116 to go in reverse, and now it won't sew fwd. Please tell me what to do. Musiclady
  • Sherry Foster Jun 29, 2008
    Thanks. I believe the mechanism is seized, and I shall have to find a technician locally to fix it.
  • cfield Jul 03, 2008
    I am having the same problem with a Singer 3116 that I have only used a few times. It will not even move forward when I try to turn it manually. Even though I have had the machine for 6 months, I have only used it a few times. I would say a maximum of 1 hour operating time. While trying to solve this problem, I discovered that if I use the drop feed control to lower the feed dogs then the drop feed control will not move the feed dogs back up to the normal position. I took the cover off and can move the lever inside to get the feed dogs back up, but it still will not move forward.
  • 323 Answers
It is possible the reverse lever is stuck in the wrong position Move it back to the forward position and see if it will work. Failing that, it's possible the machine is in buttonhole mode. Put it back to normal mode. If it still won't work, you probably have a seized mechanism which will require a technician to repair. If the machine is new enough to be under warranty return it to the store you bought it from for replacement or send it to the Singer warranty center listed on the paperwork that came with your machine.
Posted on Jun 29, 2008
I have a 3116 singer simple stuch in reverse what can i do to fix it?
What happens if you PUT it in reverse -- does it sew forward?
Nov 27, 2016 | Singer 3116 Simple
My Singer 3116 sewing machine will not sew. I try to turn the wheel and it will not go the right way but will go like in reverse.
if the machine is turning it will sew
what may be your problem is that the sewing direction is in the reverse stitch position
if that is not the case , take it in to a sewing machine repair shop for a proper diagnosis
Oct 30, 2016 | Singer 3116 Simple
Sewing in reverse
Take it to a repair shop for assessment, you will not get into a warantee ??
Nov 20, 2011 | Singer 3116 Simple
Never used, just took it out of box. sews only in reverse. cannot get it to sew foward Please help. Thank you
often there is a button or a hook you have to push or pull out to get the machine to sew in reverse. Check to see if there is something like that that you could pop back into the normal position. Alternately in older models if you bring the stitch length adjuster past 0 it will begin to sew backwards so you could try that too. Good luck!
Sep 22, 2011 | Singer 3116 Simple
3116 will not advance forward but goes in reverse just fing. Was using it than all of the sudden it stopped advancing???
The feed dog needs to be adjusted underneath or the old grease that was put on the machine now is acting like glue and is not letting trhe spring come back because it is to sticky.
Nov 09, 2009 | Singer 3116 Simple
Singer simple 3116 will not reverse
Sounds like spring or something disconnected from the lever. Take it in to your dealer or look at yourself carefully.
Feb 27, 2009 | Singer 3116 Simple
Singer 3116 won't go into reverse
here is a download for your manual
pg 32 talks about sewing in reverse sewing.
but doesn't give much on trouble shooting other than hold the lever while sewing. If that's not the case, then I think your feed dogs are the issue. check your feed dog drop. pg 9 part 12
If you think the reverse lever is sloppy, professional action should be taken, (take it in to be repaired under warranty?)
I hope this was helpful.
Jan 11, 2009 | Singer 3116 Simple
Singer 3116 Simple Logo
278 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
