Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I need to replace the starter rope on my Sears Craftsman edger. I cannot determine how to take apart the starter housing assembly. Model is a Sears Craftsman Edger Model 536.797470 Thank-you
  • Anonymous Dec 31, 2008
    I need to replace starter rope on Sears gas hedge trimmer model # 358.795630.
  • 513 Answers
It should be a shroud its all in 1 unit it should have 3 bolts holding it to the engine block un bolt the shroud & e-mail me or call me i will help you get a string in so you can use my name is wade 831-578-4034 if i may help ya
Posted on Jul 04, 2009
Where can I find parts for Craftsman trimmer housing Model 316.79186 or Enter model number get parts view and list.
Jul 26, 2015 | Craftsman Garden
Replace recoil starter on my craftsman 26 in snowblower model # 247889720
You didn't say what the specific problem is. If the rope does not return properly the best move would be to replace the housing that holds the starter. If the rope broke you will need to pull the housing off to replace it. This is a bit of a challenge because you need to rotate the spool against the spring enough times to wind up the rope when you release it and still manage to attach the rope. You may find it better to replace the housing as these springs can get weak over time.
Mar 03, 2015 | Craftsman Garden
You need to remove/disassemble the recoil starter assembly to replace the rope. Be carefull the spring does not get away from you if you do take iot apart.
Sep 21, 2014 | Garden
Pull starter rope craftsman 358-791050
there should be 4 bolts holding the pull rope and spring to the motor if you need more info. go to Sears Parts.;
Aug 20, 2017 | Craftsman 25cc Gas Line Trimmer
My Brushwacker has a broken pull start rope (model 358.795800). I figure that it shouldn't be too hard to repair it, but I would like to find a manual for repair.
Good luck on finding a manual. You can get the exploded parts drawing off of the sears parts website! I have a 32cc model 358.791580 and the pull rope broke. The pull rope assembly is located inside of the motor housing. I am having trouble removing the clutch assembly since there is no key way or screw holding it to the shaft. Does anyone know if it is threaded on?
Feb 20, 2010 | Craftsman Garden
Starter rope pulled out and wont retract on craftsman trimmer/edger 32cc convertible incredi-pull
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Oct 22, 2009 | Craftsman Garden
Cannot remove starter housing assembly on Sears Blower Vac
Take cover off were the belts are located. turn power button to off! see if the shaft can turn with a wrench. That should turn 180 degrees. If stuck you may need to forch it. Then try to pull cord.
Good luck
Jun 20, 2009 | Craftsman 4 Cycle Blower/Vac
Pull rope is striped
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
May 21, 2009 | Craftsman 25cc Gas Line Trimmer
Problem getting my craftman weedtrimmer string from being struck model 358.792150
Disassemble the starter mechanism, if rope is frayed, replace. Check movement of dogs on the starter sometimes they get rusty and freeze or do not move freely, free them up and lubricate. Check the cogs on the spool If they are worn bad, replace. Remove spool (carefully not to bring spring with it) and blow out housing below spool and clean it and spring with carb. cleaner or alcohol. Be sure to blow out the carb. cleaner with air immediately as it could attack the plastic. Now assemble, it should work much better.
Apr 10, 2009 | Craftsman 25cc Gas Line Trimmer
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
78 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
