Question about Goldstar R5050 Air Conditioner
Goldstar R1804H My air conditioner is freezing up. I keep turning it down but it still freezes. What can I do? Its over 100 outside, Which is common here.
Well u should take it out the window and dran the water out unite thwe water is gone then put it back ang if u still see that its freezing try it again and then put it one and u my have to do this offin to keep it from freezing
Posted on Aug 18, 2008
What is wrong with and Air Conditioner that continues to freeze up?
the ac cant keep up,you need a bigger ac or a smaller room,if the ac needs to keep cooling,it doesnt have a chance to cycle
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
Hi, our outside vent keeps freezing, ant suggestions on this issue? Thanks for your time.
Add a 12" piece of pipe elbowed down if possible. Also make sure the pipe is sloped back to the furnace 1/4" per ft.
Jan 11, 2015 | Heating & Cooling
Why does my central air keep freezing up?
An air conditioner freezing up is either low airflow or low on refrigerant. If the filter is clean, then check the refrigerant level, blower running at proper speed, make sure indoor coil is not dirty or restricted. Make sure that the duct outlets are all open and some have not been closed.
Sep 01, 2014 | Heating & Cooling
Ac freezing
for a homeowner the first thing to check is the filter. also make sure the fan inside is running. once the coil freezes it does make it more difficult to push air so coil must thaw. don't continue to run unit if you see ice, you are only harming the system. if checks are good you likely have refrigerant issues and need a technician
Mar 06, 2018 | Goldstar WG5000 Air Conditioner
Have Goldstar Model R1804h ac/heater window unit when turned to heat blows only cold air what is easiest thing to check and purchase first.
If your thermostat is working on the Heat cycle (listen for "click" when turned up and down on Heat), then your heating coil assembly is probably bad. The heating coil is in series with a Fusible Link and a Bi-metal thermostat, if any of these three fails, there will be no heat from the coils.The Link and Bi-metal Thermostat are made up as part of the heater coil assembly.
Jan 18, 2013 | Goldstar Heating & Cooling
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
My air conditioner keeps freezing up
Probably 75 to 80 percent of all air conditioner service calls are repaired by simply cleaning the coil fins. If it is a window air conditioner, unplug it from the wall, remove the front cover and brush the coil fins using an up and down motion. Next go outside and brush the outside coil the same way. Then blow through it with water. Too much water pressure can also bend the cooling fins. The inside coil if extremely plugged up can be washed also but it will be necessary to remove it from the window to do so. If this doesn't solve your problem, chances are that it is either low on freon or the compressor is weak. It may be time to look for a new one. I hope this helps
Jul 04, 2010 | GE AJCQ08ACB Air Conditioner
Wall ac unit keeps freezing up inside.
No! You will not likely find any service on a product which has very little value. Frosting will sometimes happen if the outside temperature is to low. The outside ambient temperature is directly related to the pressures inside the refrigerating system. The lower the outside temperature is the lower the pressures will be in the cooling end of the air conditioner. In mechanical refrigeration pressures and temperatures are directly related.
Nov 02, 2008 | Goldstar WG5000 Air Conditioner
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
Goldstar R5050 Air Conditioner Logo
203 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
