Question about Amana Kitchen Ranges
I self cleaned my Amana oven model acf7225aw. During the cleaning there was a huge pop and then all power was shut off to the oven (no power to clock or anything). We flipped the breaker- another pop. Then, the clock worked. Now the lights to the stove are not working, and the stove is not getting very hot- lukewarm at best. Any ideas?
    Novelist:
  • 161 Answers
Yes you probably have a burned out bake or broil element in the oven. They usually short out to the frame when they go and can have some interesting results. A direct short probably burned out half of the circuit breaker and you are now only getting 120 volts to the stove and its feeding back through the shorted element and giving some heat. Unplug the stove reset the circuit breaker and test the outlet for proper power. Outer holes will read 220 volts to each other and 110 volts to the middle hole. Replace the circuit breaker if needed. Usually when an element burns out it is visible. If not remove both bake and broil elements and take them to the parts store and ask them to see which one is bad. It is very unlikely they both burned out.
Posted on Jun 29, 2008
I have an older model amana electric stove; I cannot get the self-cleaning feature to work and I don't have a manual. Can you give me the steps?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 20, 2011 | Amana AER5515QA Electric Kitchen Range
Oven shur off during self clean cycle
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 04, 2010 | KitchenAid KGSA906P Gas Kitchen Range
How do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Nov 22, 2009 | Amana AGDS902 Gas Kitchen Range
Oven door latch does not lock - I was told part no longer available
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
May 07, 2009 | Amana ACF3355AS Gas Kitchen Range
Amana range ARG7800E Oven, Broiler and Self Clean will not ignite
heatman101
tti
Apr 07, 2009 | Amana ARGS7650SS Gas Kitchen Range
Atlas La Stella double oven
Hello Roland,
happy to help you out!
You must clean by way of wiping excess spills and materials dripped or spilled before self clean is operated. Or there will be smoke even during the self clean process!
Also do not wait till there is build up galore to self clean your oven!
If you spill or splatted and drip in the oven that day,
start the self clean after you do the dinner dishes!
More info can be found int he owners manual!
Aug 24, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kitchenaid kgri801pbs
there is a thermal fuse in the back of the oven that more than likely has tripped during self clean poor air flow around can cause this power surges during self clean can too you have to pull the oven out and remove back panel to find it
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
Self cleaning oven door locked before I got the door closed.
Try holding in on the door switch while resetting the clean cycle.
This should rotate the latch. Once the cycle starts, cancel it. The latch should go to the unlock position.
You will have to hold in on the door switch during all these steps.
If this does not work, post back with the complete model number from the oven and I will see what else I can come up with.
Nov 25, 2007 | GE JGB916SEKSS stainless steel Gas Kitchen...
Kitchen Ranges Logo
327 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
