I have a Canon MultiPASS MP 390. I just replaced both both ink cartrides with official Canon Inl (BCI-24) and pressed both replace buttons. It is now reading - Waste Ink Tank near full. Please advise what I must do.
  • 2 more comments
  • waddies Jun 28, 2008
    All the User's Guide says is "Contact the Canon ustomer areenter as soon as possible.
    All the User's Manual says is " Contact the Canon Customer Care Center as soon as possible.
    There was no official Customer Service telephone number or web site. I was Googled to the FixYa pay site.
    Is this the only way to get a solution to my problem?
  • waddies Jun 29, 2008
    This solution worked - the warning light and "waste ink tank near full" disappeared. Do you think this a permanent solution, or is there actually extra ink to be emptied eventually?
    Yes, but I Haven't found the "spunch" yet.
  • 1,879 Answers
Greetings,
Common issue with Inkjet printers.
That will be a temporary fix only and eventually it is bound for service.
http://www.usa.canon.com/home
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 29, 2008
    Guru:
  • 1,894 Answers
This is not an easy job to perform but you have little choice unless you want to buy a new printer.
Glued to the top of the waste tank is a piece of foam. It is exactly the same type used to filter the air in a portable air conditioner.
US cost about $2.00. You need t replace this or ink will end up spilling into the printer. Place a rag around the tank to catch overflow. You can use a paper towel or rag to slowly push it into the tank & absorb the ink. Please go slow, the ink is thicker than fresh ink & it will not come out easily. If you can get a syringe & use it to pull ink out you'll save a ton of time. Than you can use a rag to wipe out the rest of the ink. Use alcohol to wipe the top inside of tank.
Than cut a piece of foam & super clue one side to the tank. Keep it flush with the top of the tank
CREDITS:
map9966
thank you
    Sergeant:
  • 275 Answers
Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=9722
go to this link . you will find all you needs like customer service, driver download etc.. hope this will solve your problem
Posted on Jun 28, 2008
    Master:
  • 638 Answers
This is not a problem just the time for internal servicing needed to the printer.this is not a problem to worry.right corner of the printer where the ink collects in the spunch just clean the ink .and its done.its very simple.you your self can do it.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • 405 Answers
Have you tried a reset?
To do the reset follow these steps:
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
Let me know if the helps.
  • Patrick McGee
    Patrick McGee Jun 29, 2008
    Nope it's a perm, soulution, Just remeber how to do this as you may have to clear it peridocally. I'm glad I could have helped you with this problem. Thanks for using Fixya and remeber to rate the solution.
    Genius:
  • 2,028 Answers
Refer to your owner's manual for the waste tank. Some can be emptied, where as others have to be replaced.
  • Ryan Rogers
    Ryan Rogers Jun 28, 2008
    Re: MP360/390 Waste ink tank full reset combinatio by lp (8/24/05 3:34 PM) reply
    this is the sequence that worked, and do not worry about the pad, it is a sponge that you can take it out gently yourself, wash it and put it back, no soap or squiz it. do not need to open the printer to do it, can take it out from where you replace the ink tanks.
    Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
  • Ryan Rogers
    I found this at the following link.
    http://www.fixyourownprinter.com/forums/...
I need a free user manual download for a Canon MultiPass MP 390
You can get check it here:
http://soft-manufaktura.ru/manual/hp/mp390sm.pdf
Nov 15, 2011 | Canon MultiPASS MP390 All-In-One InkJet...
Black will print properly only on "High" Print setting
After all the trouble shooting you have done their most likely a hardware issues causing the problem.
Please Contact Canon for repair service or replacement.
1-800-828-4040
Nov 14, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
The same 4 bulk inks
The bad news: Canon does not make any new printers that use those ink tanks. Their line of new consumer printers is the PIXMA series. None of these printers uses the BCI-3 series of ink tanks. I am sorry for the bad news,.. The good news: I have personally been successful in finding used, operational printers for $1 to $5 from local thrift stores and for a little more at local "Recycled, Used, Computer" type of stores. You may even try craigslist and put out a wanted ad for the models below,... anyway I hope this helps you out.
Here is a list of models that use all of the BCI-3e series of Black and Color tanks
Color Printers: i550, s400, s450, s500, s520, s530d s600, s630, s630 Network, s750, all BJC-3000 Series
Multifunction Printers: MultiPass F30, MultiPass F50, MultiPass F60,MultiPass F80
Other Color Printers (partially compatable) i560 & i860 (only uses the BCI-3 black tanks,..but BCI-6 for colors)
Feb 07, 2010 | Canon i850 InkJet Photo Printer
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Hi, I just got a Cannon369 MP360 the black ink is empty,but there is color ink in it. It will not print anything. Do I have to replace the Black to get color in to work??? Since it's 2nd hand I don't want...
With this type of printer you need to have a full black cartridge to print black and white. The new Canon BCI-24 black cartridge from Staples is only $8.29. These cartridges are even cheaper from refillers. I recommend Cartridge World or Office Depot for printer cartridge refills.
Feb 02, 2010 | Canon MultiPASS MP360 All-In-One InkJet...
I have Canon MP 390 and no printing
Fill up the cartridge as printer software does not always monitor right ink level even its happens to me many times but fact is cartridge is empty fill it up thats it
Feb 11, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Cartridge recommendations
You can purchase Canon cartridges directly from Canon here. The BC-10 is a cartridge that prints with black ink only. The BCI-10 is the replacement ink tank for this cartridge (a new cartridge comes complete with an ink tank). The BC-11e is a cartridge that prints both black and color, and has two ink tanks, the BCI-11 black and BCI-11 color. A new BC-11e cartridge comes complete with two new ink tanks.
Oct 03, 2008 | Canon BJC 80 InkJet Printer
Someone gave me a Canon Multipass MP390, no disc to install it?
Hi debralee,
This is very easy.
Click here for the Canon MP-390 drive download page
Select your Operating System and follow the prompts.
If you need further assistance, just click the ASK button.
Remember: Good things come to those who rate.
Mike
Aug 18, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Used ink tank full
I have a error message on my Canon Multipass 390, used ink tank full.
Where the heck is the used ink tank?
Jul 13, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon multipass mp 390 manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=9722
Apr 02, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
62 people viewed this question
k24674
jasbo
jasbo
