Question about Dell UltraSharp 1900FP 19" Flat Panel LCD Monitor
Dell 1900FP LCD Monitor
I've had this since 2003 - just went dead (black screen). I understand that I can replace the ccfl lamp. Anyone know how to open the case? I've tried everything I can see... no luck
First, I would use a multimeter to verify that the power adapter is good. It should have an output of 14VDC. If it is working, the next step in verifing that it is a backlight problem would be to connect the display as normal and, with it powered up, shine a bright light on the screen at an acute angle to see if the desktop image is being displayed. If you can see the image, then it is probably the lamps or the inverter.
To remove the cover, remove the four screws attaching the base and after the base is removed the 2 halves of the cover simply snap together. Using a jewelers screwdriver, start at one corner and gently pry the front bezel away from the back, working your way around it. There are 4 locking tabs on each side and 5 on the top and bottom.
This display has 4 lamps, 2 each at the top and bottom of the display. This is the easiest display I have seen as far lamp replacement goes. At this point, all you have to do is disconnect the lamps wire from the inverter, remove the tiny screw, right below the point where the wires connect to the lamps, and carefully slide out the lamp assembly. Be very careful not to flex them while removing.
Check the lamps for burnt spots at the ends or physical damage. If the lamps look good then I would not rule out the inverter as the problem. At this point, if you are not familiar with electronics, I would seek help from someone who is.
I hope this helps.
Posted on Aug 22, 2008
My monitor on my Dell laptop went completely black while I was on it. I have tried turning it off and back on, and the monitor is not working at all
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 26, 2009 | Dell Computers & Internet
Monitor went dark
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 25, 2009 | Toshiba Satellite A135-S2386 Notebook
Black screen- laptop only works with external monitor
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
If your Dell has a S-video output it could connect to a TV or a video device, which allows for a TV option.
Jul 24, 2009 | Dell Computers & Internet
Black screen after startup
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 05, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Screen is black
If the copmuter appears to bootup and the hard disk LED id flashing then :- You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 27, 2009 | Everex StepNote VA4103M Notebook
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
yes your lucky thing is this problem is LCD CCFL lamp worn, change a new lamp should be fixed.
hwo to change CCFL lamp, step by step:
1) buy a CCFL lamp from eBay, reference:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Dell+Inspiron+B130+CCFL+lamp&_sacat=See-All-Categories
2) take out LCD panel
3) open the back light cover and change the CCFL lamp, reference:
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/comment-page-3/
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 28, 2009 | Dell Inspiron B130 Notebook
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Dell Inspiron B130 Notebook
Sharp Actius MM10 laptop just went dead
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Apr 15, 2009 | Sharp Actius MM10 Notebook
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
Mar 31, 2009 | Dell Precision M60 Notebook
Dell 1900FP
you can push every lamp from 19inch monitor who have same jack for conector{i work that, i have dell1900fp}!!!sorry for eng.good luck
Sep 28, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell UltraSharp 1900FP 19" Flat Panel LCD Monitor Logo
657 people viewed this question
Alun Cox
