Question about Canon Digital Rebel XT / EOS 350D Body only Digital Camera
Caon 5d err 99 - Canon Digital Rebel XT / EOS 350D Body only Digital Camera
I was getting ready for a trip to hong kong and bought a new cf card. When I put it in the camera came back with a err99 replace cf. Well after reading all there is to know about this problem i was all upset. Well at 2 a.m i went for it and I fixed the problem. One of the pin's was out of whack( it was very hard to see). I got out my small eye glass tool and gently separated the two pins....and presto it worked! It took 1 second and the problem was fixed. I am not an expert but you gotta do what you gotta do.
Posted on Dec 07, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
It's a shutter error - has to be replaced by a repair shop.
Posted on Jun 29, 2008
Error 01 in canon eos 5d
Err 01: Lens to body communication error
1.The camera to lens communication is somehow being interfered with could be a problem within the lens itself, possibly the camera body, or something as simple as a smudged fingerprint on the lens mount contacts,
2. Check the lens and the contacts
3. Also check below link if you need a canon eos 5d service manual
http://goo.gl/1rXwuc
thanks
Apr 26, 2012 | Canon EOS 40D Digital Camera
Go to take a photo everything shuts down. and a err message comes up help.
Contact a Minolta representative. They're calling back the cameras with those symptoms and will exchange it for free until Dec. 31, 2010.
Aug 24, 2010 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Err 99 keeps coming up
It is due to some kind of electrical (contact) failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
May 16, 2010 | Canon EOS 40D Digital Camera
I receive Err 99, it says to re install battery or
It is due to some kind of electrical contact failure.
May 14, 2010 | Canon EOS 40D Digital Camera
Error 99
Error 99 is sort of a catch all error code. So it can mean a few things might be wrong.
To isolate the cause of the issue, do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
If you need to have it serviced go to the caon webpage and click on support. Try calling one of the support numbers or if available the live web help. They will then tell you how to get the camera to them and what to expect. I've found them to be real good to deal with which is always nice when you have a problem.
Aug 21, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EOS Xt displays Err 99 how do I fix it.
change the lens or try cleaning the connector tabs with a eraser.
Jun 26, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 5d cannot format cf care
Hi there, did you check the card itself? SD cards have a locking switch on the side. Move the switch from locked to unlocked. Put it back in the camera and see if that helps.
Rob
Mar 02, 2009 | Canon EOS-5D Digital Camera
Nothing works!!!!!!!
Hi
Really sorry to hear all this. The Canon 5D is a wonderful piece of kit and it is not good news to read your problem. It really does sound like the unit is having a multitude of problems. This could be resulting from electical failure inside the camera. From reading through your problems you have passed the Error 99 as well. Generally this would mean hardware faults of some sort. Solutions range from chaging the CF card to Batteries to cleaning the contacts. Clean the contact is one chief remedy and cause of the Error 99 after the 'quick' fixes.
I would say try this again but this time use a rubber on the end of the pencil. Be gentle and careful not to get any dirt into thedody of the camera. Clean all contacts on the 5D Body and on all the lenses. Should this not work it may well be the case that the camera has circuit board problems.
Below is a little guide to help out which was in response to Error 99 from Canon. Hope it does. Again sorry to hear of these troubles. Canon should be more Pro active in this competative world.
It may help some
of you isolate the problem before you post a comment/question.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Jun 28, 2008 | Canon EOS-5D Digital Camera
Open Questions:
See all Canon Digital Rebel XT / EOS 350D Body only Questions
Canon Digital Rebel XT / EOS 350D Body only Digital Camera Logo
127 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
