Question about Canon EOS-20D Digital Camera with 17-85mm Lens
Error 99 Please tell me how to solve the problem
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 51 Answers
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Posted on Jan 30, 2009
When I take a photo in manual mode or auto focus my photos are not sharp & clear. I also have been shooting Macro photos & I still have the same problem. Could you please help?? Carrol.
Posted on Oct 13, 2008
When I try to take a picture I get an error 99 message. Shooting is not possible turn off power switch or remove battery
Hiyou have very common problem of canon dslr product. usually problem come from defective shutter unit. However, there is cause from lens also. Would you remove lens and push shutter button? if no error 99, then the problem come from lens---usually power diaphragm control fpc defective.If shows error 99, then you have body problem. At this point, still you have to check more. please set camera M mode and bulb shutter speed, you have to look front of camera if mirror goes up and show to you picture sensor. would you tell me more later. Thanks and best regard!
May 27, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
What is the error 619 in idea net setter how to solve please tell me
Jan 31, 2011 | Computers & Internet
ERROR 99....WHAT THE MEANING....HELP ME/ model canon 1000 D
Error 99 means "other error", so there are may possible causes. However, in most cases it refers to a communication problem between camera body and lens.
Try the following:
  • Remove the lens.
  • Check the contacts at the lens mount and contact pads at the lens for damage and dirt. If necessary, carefully clean them.
  • Power on the camera, without a lens attached. Does the error recur?
  • If the error did not occur without a lens, re-attach the lens and try again.
  • If this did not solve the problem, try a different lens
If this didn't solve your problem, please report what happened when you performed these steps.
Mar 10, 2010 | Canon Cameras
I use thais lense on a cannon rebel xti and it takes black pic
Error 99 is one irritant in many Canon SLRs. In general, it means there is some problem with the contacts. So try cleaning the electrical contacts of the body and lens with a pencil eraser.Please take care to hold the camera upside down while doing this so that the residue does not fall inside. Also take out the battery and clean the contacts. Now re-attach everything and try taking the image. Also check if your lens has an aperture ring and aperture lock. If so, lock the aperture ring at the minimum aperture. If these do not solve the problem, try updating the firmware to the latest one.
Dec 12, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Its says error 99? means? can somebody help me? saying shooting not posiblle , needs to turn off/ then turn on.. and i tried so many times but it never helps. please help me .
hi
this error 99 is generally occured when the lense is not recognized
this has been a common problem reported
we'll clear the contacts and connect the lense
try turning the Image Stabilization off and this could solve your problem temporarily
hope this helps
cheers
pls reate the solution if this helped any
Jun 28, 2009 | Tamron 28-200mm F3.8-5.6 for EOS
Error in body
Remove lens, CF card, and battery. Leave in a dry and slightly warm place for 24 hours. Clean lens contacts with a cloth or cue tip and eclipse/alcohol.
If the camera doesn't turn on after this, even without CF card and lens attached, then it needs to go to a Canon service centre. Don't tell them you got it wet, and maybe it will get repaired FOC.
Jul 07, 2008 | Canon EOS-20D Body only Digital Camera
Error 99
Trouble shooting Error 99
1. Solution: Remove and replace the battery.
Power the camera off
  1. Remove the battery.
  2. Wait 15 seconds.
  3. Replace the battery.
  4. Power the camera on.
2. Clean the lens contacts.
Clean the lens contects on the rear portion of the lens with a clean pencil eraser.
  • Mount the lens on the camera.
  • Take a picture.
If the error persists, the camera and/or lens may need be serviced by a qualified Canon Service Technician.
3. Remove the 3rd party accessory.
Please remove the 3rd party accessory and replace it with genuine Canon Accessory.
4. Solution: Remove third party lens and try with Canon EF or EF-S lens.
Remove third party lens and try with Canon EF or EF-S lens This link will bring you to the camera page on Canon's website: More trouble shooting, drivers and downloads http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=11154#DownloadDetailAct Best of luck. Could you please rate this advice. Thanks so much!
Mar 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error 99
Assuming that other lenses function normally on the camera, the "Err 99" can be caused by a failure of the aperture component in the lens. Error 99 is a generic error, so unfortunately it does not indicate exactly what is wrong. There are other factors that can cause the failure, but there is a good chance that the aperture is not functioning correctly. You can try cleaning the electrical contacts on the lens, if this does not work you may need to get the lens serviced. Check with Canon, or check the web for other repair service providers. David Millier Advance Camera Repair
Mar 05, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EOS-20D Digital Camera with 17-85mm Lens Logo
196 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
