Question about Karcher 2500 PSI Pressure Washer
I purchased the karcher for kids washer and can't connect to garden hose...is there some attachment neded??
  • 33 Answers
There should have been an adapter from the factory on it. if not you can go to the dealer and get one.
Posted on Apr 21, 2009
Karcher Leaking from Back or inside...Help please
Karcher pressure washers are very sensitive to over-winter freezing. The plastic parts break, and you have to replace all of the leaking parts.
You may be missing a locking tab, without seeing the thing apart next to the exploded parts view, it's really hard to tell. Search google for "karcher parts", and put in your model number...
Aug 03, 2015 | Karcher Garden
Karcher 3.190 breaks hose coupling connector
use high quality brass fitting, low quality brass will break also,replace male and female side with matching brands
Mar 30, 2014 | Karcher Garden
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
The garden hose was used to siphon water from a dirty pool. The hose was connected to the pressure washer without cleaning out the hose and turned on. After a few minutes he couldn't get pressure from the...
Hello, check the hose connection on the pump. There is generally a screen there to prevent dirt from entering the pump. Clean off this screen and all should be well.
joe
Jan 27, 2011 | Karcher K3.68MR Electric Pressure Washer
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
Hose out of the karcher unit blows off
Sounds like you need a new hose if it keeps blowing off the unit, see attached link to purchase the hose.
http://www.wmpcs.com/index.php?main_page=product_info&cPath=81_55_58&products_id=286
Oct 29, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
No pressure HOSE IS BIG ENOUGH,NO KINKS, FILTER IS CLEAN. TOOK THE PUMP APART AND CHECKED ALL THE CHECKS, THEY WERE ALL OK.WHAT ELSE CAN I LOOK FOR? THE PUMP IS A KARCHER-MODEL G 1800 LB Thanks, Art
Brother Art,
Try this trick; it always works for me. Assemble the garden hose to the washer, install the HP hose, turn on the water. Now, make sure that there is no air trapped in the garden hose. Manipulate so as to direct any air trapped in the line to the washer. Connect the gun and continue to allow water to "free flow" for several minutes. Now, work the trigger, allowing the unit to rise to "house pressure, and then pull the trigger, dropping the pressure suddenly. This displaces any air hidden in the system. Do this several times, and start the washer up. If this doesn't get you up to pressure, repeat the above on an abbreviated scale, and hold the trigger on the gun down while you start the washer. This should do it.
Regards, --W/D--
Aug 08, 2009 | Karcher Garden
I can't connect the garden hose to the water inlet. I am using a size 5/8'' hose but it wont connect to the unit. Please help!
Karcher electric pressure washers typically are supplied fitted with the male half of a standard Hozelock connector. You need the female half secured to the end of your hose, and then they just click together.
May 16, 2009 | Karcher PSI Electric Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
77 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
