Back to:
Tags:
OfficeMax Shredder
Officemax shredder OM96146 Paper stuck in teeth
posted by bbustaj68 on Jun 28, 2008
The paper is getting carmed in between some of the teeth. It's not under warrenty. Taking apart revailed that the plastic fingers that cleans them out are broke. Where can i get replacements? Thank you
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Shredders problems?
OfficeMax (0M96431) Shredder
broken several teeth on main neylongear wheel, where i can...
Able to reverse, but will not accept any new shredding....
Hello: My OM99731 shredder is jammed and will not start. I...
Put in lubricant sheet and shredder worked fine for aobut...
Loading problems.
Repair Service
Find Shredder Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
