The image turns a reddish hue and the image expands after about 15 to 20 minutes of use. The Windows icon on the start button disappears into the left side of the screen after 2o minutes of running. I had my PC into Best Buy and they ran a stress test on the system. The PC checked out fine. Please help. Richard
  • 46 Answers
Hello Richard.
Make sure that the monitor cables are properly connected when the colors change sometimes is related bacause the connector to the PC is lose (or at the monitor). If the problem persists, try with the power cable.
Posted on Jun 28, 2008
My cursor disappears after turning on my Dell Inspiron.
Try pressing on the windows button. Does it change something? Does the start menu pops up when you press the windows button in your keyboard?
May 27, 2013 | Dell Inspiron Computers & Internet
I have a motion tracking camera. It says its installed properly, and the ulead software it came with installed. At first, the icon was on the taskbar. I clicked. Nothing. Then the icon disappeared. I went...
You may have a conflict - try disabling the built in cam
> Start > Control Panel > Classic View > Device Manager
Expand the 'Imaging' Folder and right click on the built in laptop webcam text - select 'Disable'
Lots of problems here with Windows 7 and webcams
If it still gives problems trial it in Compatibility Mode
Right click on the webcam icon on your desktop or the webcam file from 'All Programs' - select 'Properties'
Select the 'Compatibility' tab
Select 'Compatibility Mode'
Use the dropbox to show the OS you have successfully used before
Click OK
Restart your computer
Everything mentioned is reversible so worth a try
Aug 23, 2010 | Gear Head WC755IPT Webcam
Black screen
Usually when you see a reddish hue then indicative of an inverter or backlight failure. Hold the laptop up after it is started and look from the bottom toward the top. Try to shine a flasklight at the bottom of the screen upwards...see if you can see the windows startup screen or anything that gives an indication that the laptop is running and booted to where you can faintly see something on the screen. If you can barely make out an image, then 9 times out of 10 you need another inverter. There are rare occasions that a backlight bulb will fail, but this is rare and most backlight bulb failures are from shock damage. The inverter can be changed by simply removing the screen bezel, unplugging the inverter and changing it. If the bulb has been broken or burned out, it is more cost efficient to simply change out the lcd panel. The bulb sits in a channel under the lcd panels inside the aluminum framework. The panel has to be disassembled to remove it.
May 23, 2010 | Toshiba Satellite Notebook l505dls5005
Only reddish hue color for entire screen
In most cases these CRT projection sets made by Samsung for Akai are notorious for fouled cooling liquid in one or more of the CRT's. The CRT's in most cases are no longer available.
Aug 14, 2009 | Akai PT5598HD 55" Rear Projection...
Pictures to dark
Issue: Tinted printing / Colors are not exact
Solution: Disable Monochrome Effects in the printer driver (Windows)
Disable Monochrome Effects When Monochrome Effects is enabled from the Effects section of the printer's Properties/Preferences, the printed image will have a definite color hue. Follow the steps below to disable Monochrome Effects.
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes').
  2. Windows 2000/XP: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Effects tab, click on the 'Monochrome Effects' check-box to remove the check-mark.
  4. Click the 'OK' button at the bottom to save the setting.
Sep 17, 2008 | Canon PIXMA iP1600 Printer
Desktop icons disappear when logging on
sounds like you have the display settings for power save set on short cycle.
start button on bottom left click once(leftclick)
open control panel
do to display(Windows xp) double click
go to settings
click on power settings
change to a longer time table
If you like we can do this with our screen sharing service. see my email in my profile for connecting with our team.
Feb 17, 2008 | Toshiba Satellite A105 Notebook
Bad image quality
try to uninstall the driver software and install again.. if nothing happens, try another webcam.
Dec 29, 2007 | Logitech QuickCam Express Web Camera
Reddish hue on monitor
just switch it off and swith it on
Sep 22, 2007 | Compaq FP 7317 17" LCD Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
