Fan #2 replace for samsung tv HLS4266wx
1- is fan #2 @ front of tv, the bigger one, not the smaller one when u remove access cover.
2- guts slide out some but not much & cannot get last 2 srews on fan,
there is a thick black cable with big white plastic adapters each end-one end prevents guts from sliding out more. i tried lightly pulling on it but very secure. is that cable safe to disconnect to get better access?? i do not want to break any sort of seal if is one?
  • 2 more comments
  • bjn7295 Jun 28, 2008
    Did not answer Quest. # 1 only #2--please confirm # 1 quest.
    there is no srews securing cable, as I said, female adapters on each end--one endconnects to board & other connects to cable options area & that end blocks guts from sliding out all the way. and is fan # 2 at front of tv, the bigger one. please read original quests.
    gotten 2 incomplete responses so far?
    gotten 2 incomplete responses--is this some sort of scam site--people just say they are experts & give incomplete or vague answers?
    They should be very simple questions for experts. What is the problem!
    thank you bestdarn, very clear & simple.
  • 3,037 Answers
1. Fan number two is the bigger one
2. Cable is safe to pull out but I would recommend having the tv unplugged for 8 hours to let it discharge before working on it, you may have already done this but it is better to be safe than sorry
Let me know if you need anything else
Posted on Jun 28, 2008
  • Benjamin Patri
    Benjamin Patri Jun 29, 2008
    Please don't forget to rate this solution that I provided whenever you are satisfied with my service provided here. Let me know if you have any more questions
  • 2,794 Answers
I don't schematics for it but I don't think there is a seal on there if it's secured by screws. Whatever it takes to get it out and put a new one in should do the trick otherwise you might have to take the whole cage out.
The important thing is not to drive a screw through the cable or break it in any way.
Good luck on that.
    Genius:
  • 2,028 Answers
Yes it's safe to disconnect this cable, there is no factoy seal.
Where is "fan #2" in Samsung dlp hl-r5656w?
I don't know which is fan #2 but if you take the back off, you will see one fan right in front of you. The other is harder to get to. It's the black box inside the silver covering with the holes (in left lower part).
My TV was acting up by having only one color showing until I let it cool down then it would work fine. I cut a hole in the plastic back cover and mounted a bigger computer fan. Just spliced it in the wires of the little fan. Fixed the problem
Jan 26, 2013 | Samsung HL-R5656W 56" DLP HDTV
I have a Samsung DLP 50" HDTV HLS5086w, and I need to know how to find and remove fan # 2 from inside the TV so I can replace it but when I open up the back I can't see it anywhere. Only fan 1 is...
Fan #2 is the fan that blows air accross the lamp itself. It sits in the far upper right corner covered by a shroud. The ONLY way to remove the fan is to remove the complete light engine itself. I would recommend a technician to do so : )
Jul 27, 2011 | Samsung HL-S5087W DLP TV
I am 99% sure I have a bad fan. TV was turning off (probably overheating). We replaced the lamp (for the fourth time), but the fan continues loudly when the set is turned on. Question-- Can I replace...
Tools/Supplies:
• Phillips screwdriver (magnetic tip)
• 1/4" nut driver
• 1/4" wrench, small adjustable wrench, or stubby Phillips (to access screw in tight spot)
• Canned air with extender tube, a few cans
• Optical-quality microfiber cloth
• Clean, lint-free cloth
• Small brush
Precautions:
• Do not use any cleaner that contains ammonia. A clean lint-free cloth dampened with water was adequate for me.
• To prevent over spray, do not spray any cleaner directly on to any TV part. Spray on to rag only. (I only used a dampened rag to clean plastic and metal surfaces; no electronics or optical surfaces.)
• Use only an optical quality microfiber cloth and/or canned air to clean the light engine lens, the mirror and the inside surfaces of the front screen.
• Exercise caution using canned air. Do not tilt the can and allow any liquid propellant to escape. I had a few full cans available, and swapped to a new can often.
• Keep screws removed from each panel in a different cup. Most are different sizes.
• When disconnecting wiring connectors, note color codes for connector orientation when reconnecting. Most connectors only install in one orientation, but it's not clearly obvious.
• If contacting any circuit boards/wiring connectors, make sure to touch the metal frame first to discharge any static charge.
Disassembly Instructions:
1. Insure TV is powered off and allowed to cool at least 2 hours (overnight if possible).
2. Open and remove the Lamp Unit door on left side of TV. Using a Phillips screwdriver, loosen the 2 screws on the lamp unit and carefully remove the lamp unit.
Clean lamp unit, using microfiber cloth on the lens and set aside for reinstallation.
3. With the lamp unit removed, you can see the light engine's color wheel through the small hole. I covered this hole with tape to prevent any dust from entering during my cleaning.
4. Remove the lower rear cover (2 screws on each end and 9 along the back panel).
5. Remove the cover from the Input/Output jacks by removing the 7 silver screws securing the cover to the Input/Output modules and sliding the cover off the power cord grommet.
6. Remove the front pedestal cover as follows:
Note the blue, red and grey wire harnesses on the right side leading to the front panel controls, AV-3 jacks and PC slots. Loosen and remove these wires from their wire ties.Grasp the pedestal cover at the ends and gently pull outward. It is installed with quick-release pins and should release easily.Gently pull the pedestal cover out, being careful to guide the wiring.Carefully disconnect the 3 wiring connectors, noting the color code for reconnection.In preparation of removing the front screen, 2 hidden screws must be removed. These 2 screws secure the bottom corners of the front screen and are installed from the back.
7. Remove the plastic housing where the lamp unit was removed:
Loosen the wire tie and remove the wires from the top of the plastic housing (these wires go to the lamp door switch).Remove 2 screws securing plastic housing. One on left side and other in base on right side (with limited space available, will need 1/4" wrench or stubby Phillips).Slowly pull housing from TV, until you can reach the connector to the lamp door switch. Note color code and disconnect wiring connector (may be easier to pull some wire through the hole and lift upward to remove connector).The front panel screw can now be seen in a recessed hole. Loosen this screw. (I did not remove the screw completely, to aid in reinstallation. Otherwise, a magnetic Phillips screwdriver may be needed.)8. From the area of the front panel wiring ties the other hidden front panel screw can be seen in a recessed hole. Loosen this screw.
9. Remove 11 of the 12 screws along the back of the TV securing the front screen, leaving one loosely installed at the top.
10. Remove 4 of the 5 screws on the front of the TV, at the bottom of the screen.
11. While holding the screen at the top and bottom, remove the two remaining screws, and gently lift and pull the front screen panel away from the TV.
Store the front screen assembly where the inside surfaces can be cleaned with the microfiber cloth and/or canned air.
12. Reassemble the TV in the reverse order, remembering to remove the tape from the hole covering color wheel, if installed earlier in step 3.
There are 3 fans to clean:
The large Lamp Fan behind the lamp and light engine assemblies is clearly visible.There are two smaller fans mounted next to each other. One fan is mounted between the cable card slot and the light engine and the other fan is mounted just to the right directly on the light engine assembly. It's somewhat inaccessible without removing the light engine, but using an extender tube on your canned air, it is easily cleaned.
The lens of the light engine will have the most dust. Clean with canned air and the microfiber cloth. Use a corner of the cloth to reach beneath the plastic tabs covering the lens.
The mirror may have a few dust particles. Gently wipe with the microfiber cloth and use canned air. Hope this helps,
TechGuy21
Jul 04, 2011 | Toshiba 62HM95 62" HDTV
How do i take my Acer Aspire 5532? i want to replace the processor, but the gut's are like a poorly designed obstacle course. :(
Usually the first thing on a laptop is the keyboard, then pry the plate above the keyboard (between lcd and keyboard), this will give access to the lcd hinges and connection. Remember to remove all screws, covers, drives, battery, memory and ethernet card BEFORE taking anything apart. Unplug the lcd, pull the wireless antenna wire through from the bottom of the laptop then remove the lcd. make sure there are no screws through the case from the top. then you simply pry the top off the bottom, be sure to start from the back as the front of the aspires are usually hinge style clips-meaning when you put it together tilt the top toward you, slide the front clips in place locking the front down then press down on th edges from the front to back to snap it together). After the top is off remove screws from the heatsink and fan, disconnect the fan and remove heatsink. There you go, install opposit of removal.
Jan 24, 2010 | Acer Aspire 5315 Notebook
Not sure how to get access to fan ballbearings to lubricate them. I got the front piece off but don't know how to slide the motor out to see the fan. I didn't buy the unit so I don't have the manual.
you cant access the fan motor from front you have to take the outer metal cover off and then the guts or inside part of the unit will slide out then you need to take the insulated cover that wraps around where the motor is on some of those units some of the styrofoam even has to come out till you can get to it, but dont be suprised if once you get to the motor it may be a sealed motor with no oil ports depends on how old unit is .its actually a real pain to get to and then putting it back together will take patients.good luck i hope that helps
Sep 10, 2009 | Maytag M6X08F2ACOM Air Conditioner
How do i installl ram into a averatec 7100 series?ive opened the two panels under it. the bigger one isnt not the ram. the smaller one seems like it is but there is a foil like cover and there is screws to...
That is your Hard Drive. The 2 screws to right will let you slide it to the right and lift it out.The larger panel with the fan in the upper left corner will allow you to access the RAM. There are 2 RAM slots just below (not under!!) the fan. They have metal clips to hold the RAM strips in place and are staggered like steps.Ground yourself!!! to avoid ESD damage to parts...Hope this helps
Jul 14, 2009 | Computers & Internet
Check fan # 2
Samsung Consumer LCD tv's do not have fans except on the higher end models. The Commercial models do. Yours is a Consumer model. I suspect that you have a DLP tv. In that case replace the Lamp Fan. It is the Larger of the three fans. With the rear cover off, you will see a Blue switch lever on the lower right side of the tv. Hold it in a up position and turn "on" the set with your tv remote. Then look for any fan that is not running. Then order that fan. there is a large fan that cools the Lamp. The other fans are of the same smaller size and one cools the DND chip and the other cools the Ballast.
Jul 04, 2009 | Samsung Televison & Video
How do you get the water pump and fan disconnected from each other on a 1997 Dodge Pickup truck 318 motor?
you need a special tool , a fan nut tool , it's like a 1-1/2 " ,actualy a little smaller , i use a 1-1/2" wrench and smack it with a rubber mallet , but there is a tool for it , i think checkers auto has a loan -a-tool program , but to buy it is expensive , it is normal threaded - counter clockwise is off . a special tool holds the 4 bolts on the pulley and the other part of the tool fits on the big nut . sorry i can't fix ya , cuz who has a 1-1/2" wrench or the special wrench in there home arsinal .
J5
Jan 22, 2009 | 1999 Dodge Ram
Opening the case to increase memory on Poweredge 1800
Hi
First, turn off the system including any attached peripherals, and disconnect the system from its electrical outlet.
1. Using the system key, unlock the front bezel.
2. Slide the latch right and pull the top edge of the bezel away from the front panel. Pivot the bezel downward until it is at an angle to the panel. Remove the bezel from the slots on the panel.
3. Loosen the three thumbscrews on the left side of the cover.
4. Grasp the cover at both ends and slide it towards the front of the system. And lift the cover away from the system.
5. Press the release tab on the front and back of Fan 2 assembly, then slide the fan assembly (black plastic shroud) up and out of the system
6. Disconnect the power cable for the Fan 2 assembly from the system board.
You can now access the six memory slots. Review System Memory / General Memory Module Installation Guidelines and carefully install the new memory modules.
I have provided some pictures below to help you.
Mike
Jul 11, 2008 | Dell PowerEdge 1600SC Server
Televison & Video Logo
245 people viewed this question
Top Televison & Video Experts
