Question about SanDisk Sansa e260 MP3 Player
How do i put sansa in manu mode? - SanDisk Sansa e260 MP3 Player
  • 8,596 Answers
What is manu mode?
The manual is here:
http://www.sandisk.com/
Posted on Jul 06, 2008
MANU button on RAV4
The PWR button (power) is like a sports mode. It keeps in lower gears for longer so you can gain more speed. Handy for overtaking or fast lane changing. Not wise to use this all the time due to poor fuel economy.
The MANU button (manual) allows you to operate the gears manually. With MANU on and gear lever in L, it will drive in 1st. Gear lever in 2, it will drive in 2nd. Gear lever in D, it will drive in 3rd. If Overdrive is enabled then D will give you 4th gear instead.
Apr 13, 2010 | 1996 Toyota RAV4
My Sansa Express MP3 player does not show up on my computer as "Sansa Express" but is shown as Removable Disk (K:). Is this right
Normally your Sansa Express would show up as "Sansa Express", which would indicate that it is in MTP mode. The Sansa Express doesn't supply a menu option to switch to MSC mode, which would cause it to show up as a "removable disk". Apparently your Sansa Express has somehow switched to MSC mode. MSC mode is necessary for upgrading firmware, in which case it's called "recovery mode", and it's possible that some combination of key presses (usually involving holding down the power/hold button) put it into this mode.
If you double-click on "removable disk (K:)", do you see a Music folder? If so, is there anything in the Music folder?
Feb 11, 2010 | SanDisk Sansa MP3 Player
How to put music in a sandisk sansa
Download the Manua; after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer2.gif is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
You can make another music folder (music1)put music in this....
Oct 25, 2009 | SanDisk Sansa e260 MP3 Player
I downloaded a Sansa video converter and it keeps saying that my Sansa is not connected after i connect it. Can i have some assistance please?
do u have windows or mac system? if mac,
Although MAC OS is NOT a supported operating system, the Sansa player can still be recognized if the Sansa player is only plugged in MSC mode.
MAC computers do NOT support MTP
A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized.
MAC computers supports Sansa players in MSC mode
Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
See answer ID 207 for instructions on how to put your Sansa player in MSC mode.
See answer ID 1141 for instructions on transferring music to your Sansa player using iTunes on a MAC computer.
Aug 01, 2009 | SanDisk Sansa e260 MP3 Player
Sansa software download
by miistake i removed config files
now it is not powering up
not getting startted
manu
Jul 27, 2008 | SanDisk Sansa m230 MP3 Player
Charging sansa mp3
try putting it into recovery mode. you can do this by putting the hold sign to where it shows orange, then holding the record button down while holding the power button down and continue to hold them at the same time. make sure your sansa is plugged into the computer while you put it into recovery mode. for more information here is a link to the forums where they tell you how to put it in recovery mode http://forums.sandisk.com/sansa/board?board.id=e200
Feb 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa Player - Unrecognized USB Device
alrigth it seems like you have formatted the recovery partition
if your sansa are working .. well if it´s starts then you should try
to go into recovery mode by having hold (on) and push rec button while starts the mp4 if it comes into recovery mode there then you can relese the rec button and connect the mp4 to the computer there you should see a device (15-16 mb ) in there it should be a file named : pp5022.mi4 you may try reset your sansa ( change the pp5022.mi4 file) you can download from http://chrisjs.com/PP5022.mi4
if you can´t come into reovery mode you got to do following
take it step by step and carefully read all twice before you starts:
you need to download ubuntu live cd learn more about that on www.ubuntu.com it´s is a open source os it´s free and anyone can change stuffs ect...
then burn ubuntu 7.10 to a cd or dvd
in the iso file i think after burning close the cd
and boot from the live cd with ubuntu so then when using ubuntu (you dont need to install it ) you do this :
There's four files you need to get, plus one you need to create. Copy and paste the following lines:
mkdir ~/e200t
cd ~/e200t
wget http://daniel.haxx.se/sansa/e200tool/e200tool
wget http://daniel.haxx.se/sansa/e200tool/i2c-e260.bin
wget http://daniel.haxx.se/sansa/e200/BL_SD_boardSupportSD.rom
wget http://chrisjs.com/PP5022.mi4
touch sansa.fmt
After everything finishes downloading, check the md5sum for each file:
md5sum *
That should return:
af26eb02fc3454f5264bb028107a2700 BL_SD_boardSupportSD.rom
d9f946067844e2a24fcbb6cfedb75057 PP5022.mi4
795cc4e75d38284a1460b840fc14967a e200tool
cecb257eeb64ceaae9cb20d9956a0bfc i2c-e260.bin
d41d8cd98f00b204e9800998ecf8427e sansa.fmt
If any of those lines don't match, redownload the file and check the md5sum again.
Then, make the e200tool file executable, switch to root (if you aren't already; enter password if needed), put your Sansa into Manufacturing mode, and program the i2c:
Keep in mind - there seems to be a 15 second timeout for Manu mode, so if you get a -71 error, try again.
chmod +x e200tool
sudo su
(Put sansa in Manu mode)
./e200tool init
./e200tool i2cprogram i2c-e260.bin
Also, you can use that i2c file even if you don't have an e260 - they're all the same.
I don't have a working Linux computer at the moment, but I believe at this point you need to turn your Sansa off. Hold power for 15 seconds, then go back to Manu mode.
Next, recover the bootloader to get to recovery mode:
./e200tool recover BL_SD_boardSupportSD.rom
When the display turns on, hold the REC button. If you don't get into recovery mode, try again.
Once in Recovery mode, place
i2c-e260.bin, BL_SD_boardSupportSD.rom, PP5022.mi4, and sansa.fmt
on the recovery mode drive.
Disconnect the sansa, turn off hold, and it should (hopefully) work. (chris did help me with this )
if you got any problems send a mail to skrap94@hotmail.com and write sansa e200 in top off message and try to say the problem if you got one let me know if you fix it it always fun :D
hopes this helps
Jan 12, 2008 | SanDisk Sansa e260 MP3 Player
Sansa wont work
Once you have it in recovery mode, create a file called "sansa.fmt" and put in on "16mb" (Which is what your sansa shows up as in My Computer when it is in recovery mode). Once you have put the file on the "16mb" disconnect the cable and allow the device to restart unlocking it before it boots back up.
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 datadase fail or memory bug need backup... Thanks
switch to recovery mode! here:
copy and paste the following link into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your Desktop.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Once you have downloaded the file, please follow these instructions.
1) Double click on My Computer so that you can see it on your screen.
2) Turn the player off.
3) On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see Orange.
4) On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under My Computer called 16MB FORMAT. Once you see that icon you may release the Record button.
5) Double click the file you downloaded earlier and run it. Follow all of the on-screen instructions, and when you get to the prompt where it asks you whether you would like to Format it, choose Yes. Once it is done, click Finish.
6) Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
7) Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
