Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
The fridge compartment seems to be very cold but the four drawer freezer is not freezing ice cream/pops at all and only partially freezing meat can you help?
  • 5 more comments
  • kabrahamjini Aug 04, 2008
    i have problam
  • Anonymous Nov 29, 2008
    Fridge Cold 4C. Freezer compartments are defrosted. The whole unit is in a garage which has no heating. Seems to me it is sensing the outside temp and the freezer then warms up? Is there any cure except for putting it in a warm spot?
  • Anonymous Mar 15, 2014
    Can you freeze fresh corn beef
  • Anonymous Mar 18, 2014
    freezer not cold
  • Anonymous Mar 19, 2014
    New fridge been installed for 6 hours still not making ice the red light is on in the icemaker
  • Anonymous Mar 27, 2014
    How to tell if cooked pork is bad? Came from freezer; but is darker in color.
    Is the meat safe to eat--frozen cooked pork dark brown .
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 28, 2008
Frigidaire FRS26LF8CS3 Side by Side, Freezer ice/cream melting, lower bin food side freezing
(There is a defrost heater on the evaporator in that area.If
you have a VOM you could check it with the power plug pulled out of the wall socket)
if you access the area turn the defrost timer on (clockwise)it should get warm in that area and you shoud hear a popping sound
If you want to tackle the job for yourself all the manuals are here
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FRS26LF8CS3&User=&Search=Search
Nov 27, 2007 | Refrigerators
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
GE REFRIGERATOR
can you see thick frost on the back wall or the bottom of the freezer compartment? if you do, you have a defrosting problem.
Feb 21, 2008 | Refrigerators
Bosch Classixx fridge / freezer
Hi - experienced this myself and spent ages trying to get to the bottom of it - only found one post but it worked and was absolutely clear on the cause nb: i'm not an "expert" !
My understanding of how the Bosch f/f works is that the freezer compartment generates the cold air for the fridge which is regulared at the fridge end . At the back of my fridge there are two "vents" which feed up this cold air up from the freezer into the fridge.
Problem happened to me because I left the freezer door slightly ajar which generated a massive amount of frost (sucking in the moist air from the house I guess then freezing it) and subsequent ice froze up the cooling ducts between the freezer and the fridge. Therefore, no matter how much I turned up the fridge thermo it never got cool. Only solution was to dump my frozen at a mates house and defrost the the FREEZER for a good 24 hrs +.
Worked tho' - fridge was completely back to normal.
PS: I understand this issue may also happen if you put too much unfrozen food into the freezer at one go and in working overtime to get it frozen causing a massive frost up again.
Nov 01, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
1,914 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
