Question about Haier HLF11P 6 cu.ft. top load washer / dryer
Won't start lights come on, but just flash when i hit start. Micbeth1981 suggested unplugging and plugging back in, which I had already tried. Also suggested I check the door switch, which I did, and that doesn't help. Any other ideas?
  • 481 Answers
You can also check you breaker, sometimes only one side of a 220v breaker will trip and the machine will still seem to have power but it does not have the full 220v. worth a try, turn your breaker off and then back on.
Posted on Jun 28, 2008
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Car alarm keeps going off and car wont start
try this: dicinnect battery fir 15 minutes , then reconnect. turn the key to the on position for 15 minutes , then try to start. You may need to reestablish communication in the vehicle.
Jun 12, 2017 | Volkswagen Jetta Cars & Trucks
TV will not turn on. I press power and it sounds like it's coming on and then clicks and the stand by light flashes 7 times. Have already tried unplugging and then plugging back in after a minute
When I called a tv repair company the rep said this usually indicates that the "lamp" for this model needs to be replaced. Since he TV is so heavy he suggested that I access the trap door in back of the console and detach the "lamp" myself and bring the lamp to his shop for replacement. Approximate cost for the lamp is $200.00. Wish me luck.
Dec 01, 2011 | Sony FD Trinitron KD-34XS955 34" TV
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
ONLY LAMP LIGHT FLASHING WHEN PLUGGED IN, WON'T START, NOYHING HAPPENS WHEN YOU HIT THE POWER BUTTON.
make sure the lamp cover is in good and the screw is snug just had mine open and only thing that it does is red light flash and nothing on screen......unplug power and try it then plug it back in about three or four minutes later.....hope that helps
Nov 15, 2010 | Hitachi 50VS69 50" Projection HDTV
My dishwasher's "clean" light is flashing and when I try to hit the start key nothing happens. Have tried to open/close to restart and also tried to hit the cancel key.
Some dishwashers are unplugged under the sink. Unplug it for a few minutes and plug it back in to see if it will reset. Others are wired in behind or under the unit. Go to your fuse box and turn off that kitchen fuse. Then wait and turn it back on. Just an idea.
Sep 20, 2010 | Whirlpool Dishwashers
LC 32D43U power and OPC green light flashing set does not come on
hey i have had the same problem but i unplugged the tv for awhile about a half hour and then plug your tv into a different wall outlet if you can and should work. It worked for me, i had it plugged into a surge protector then i unplugged it from there, let it sit of half hour then plugged into different wall outlet and worked. so try that and see if it works.
Dec 29, 2007 | Televison & Video
F-00 flashing control panel w/ time
pannick!........ suggest you check the filter, the fault code suggests that for some reason it cannot empty. Regards Engineer
May 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Haier HLF11P 6 cu.ft. top load washer / dryer Logo
96 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
