On booting up the advent T9509 desk top Pc. I only get the large ADVENT sign in middle of screen plus along the bottom of screen bios menue press keys,and some other instructions, but clicking on any of them does not do any thing. Any Help Appreciated. I am not very computer litrate, but would like to try and solve the problem my self. Regards John
  • 20 Answers
SOURCE: I have an Advent wireless keyboard problem
Your keyboard is probably set to the wrong region.
Start, control panel,Regional and language options,languages,details.
select united kingdom keyboard and delete the usa one.
this is right for XP - If your using Vista it might be different.
Also I bet the @ key will give you a " sign so this could be a temporary fix
Posted on Feb 28, 2008
SOURCE: Computer won't boot up
you must hold down the F10 key( for system recovery) when you turn on computer. hold down as computer starts up,hopefully it will then repair itself and boot up. If not,start up computer holding down F12 for advanced diagnostics and run some test!! Good luck
Posted on Mar 07, 2008
SOURCE: Advent T2310 laptop screen blank
Have you tried it with an External monitor?
Posted on Mar 10, 2008
Pyrhyc
  • 2028 Answers
SOURCE: laptop advent 7098
Let me start by saying, this message is usually an indicator that the hard drive has failed and needs replacing. Sometimes you can get away with an operating system reload, but more often is hard drive replacement.
To check the bios settings, you will need to enter the bios at start up. There will be a screen that tells you which button to press (usually F2) in order to go into the bios or utility set up. Some machines don't give you much time to do this, so you'll need to be quick. When in the bios, check to see if the hard drive is enabled, if there is that option, some don't have the option.
If the hard drive crashed or failed it wasn't your son's fault, it would have crashed no matter who was using it at the time. Hard drives do this, they have a small electrical motor in them, and just like the starter on your car, they work or they don't, and will fail without warning.
Posted on Jun 27, 2008
kornho
  • 781 Answers
SOURCE: Computer will not get past the BIOS screen
it sounds like a problem regarding the POST process (power on self test) which is the first thing your computer does when booting up when testing the components that make up your system to make sure it has what it needs to start booting. which in your case could mean you may have a hardware problem. do you know what jumper on the motherboard you were trying with?
Try to reset your cmos by removing the cmos battery, waiting a few minutes, reinstall the battery and try to restart?
if possible post what system you have to get more details on how to reset your motherboard:
look for your system here:
http://support.gateway.com/support/supinfo/index.asp?pg=2&file=510series.html
Posted on Sep 27, 2008
When I power on my Advent Tacto the Advent logo comes up and then just sits there. I have tried break on power up but that makes no difference.
Removing the hard drive will not boot to the BIOS. Try pressing F2 when your laptop is booting. Change the boot order to your hard drive.
Sep 18, 2016 | Advent Computers & Internet
Restore advent z100
This process will erase ALL data. Your music, email, pictures, documents and other important files will be deleted.
Make a backup of everything you need to keep, before starting Advent Recovery.
To recover your Advent:
As soon as you press the power button on the computer, press F8
You will see an Advanced Boot Options menu screen, select Repair Your Computer
Once the recovery program has loaded, select Reinstall Windows
On the next screen select Start Full Destructive Recovery
Another screen will be shown and you will need to put a tick into the box to start recovery. It will also give you another warning about data loss.
Press the arrow that points to the right and the process will begin automatically
Your computer will take around 30-45 minutes to complete this and can be left to get on with it. Once finished, Windows will be reinstalled and your computer will be just like the day you bought it.
Jan 02, 2015 | Advent Computers & Internet
Advent t9610
By pressing DEL can you enter the BIOS setup screen? If so, can you see the hard drive designated? It is usually in the initial screen where it lists all recognized peripherals, including your DVD drive and (hopefully) your hard drive.
Mar 14, 2014 | Computers & Internet
Advent 4211 screen to base connection problem
Video Cable
The Video Cable connects to the motherboard.
It then runs along under the Left Hinge, and connects to the back of LCD screen.
{LED backlighting. Does not use a screen Inverter]
Due to just normal opening, and closing of the laptop; the Video Cable may be pinched.
This can cause the connection of the Video Cable TO motherboard, to be loose; and/or LCD screen.
Solution is to partially disassemble the laptop, and PHYSICALLY make sure the connection at motherboard is tight.
Visual inspection will NOT do.
Connection at back of LCD screen needs to be Physically checked also. (Try to plug in tighter)
Also visually inspect the sheath of the Video Cable, for apparent signs of damage.
Any signs of damage to the sheath, may mean damage to the tiny wires inside the Video Cable.
(Stretched/Broken)
Also due to the age of the laptop, suspect cracking of the insulation, of the wires inside the Video Cable.
If you have a multimeter, set it to OHM's (1K), and check continuity of every wire in the Video Cable.
Or take it to a small computer store, and have the resident tech check it.
The Advent 4211 is just a rebadged MSI Wind U100, according to my findings,
Disassembly guide,
http://www.bit-tech.net/hardware/laptops/2008/07/05/breaking-wind/1
That's the problem, the Video Cable,
http://microdream.co.uk/advent-4211-c-lcd-screen-cable-k19-3030019-h58.html
[ In the photo, the large connector at bottom plugs into the LCD screen.
The smaller connector at the upper right plugs into the motherboard.
The separate black wire you see with the eyelet on it, is a Ground wire ]
For additional questions please post in a Comment
Regards,
joecoolvette
Dec 14, 2012 | Advent 4211c Notebook
My advent netbook starts up saying Insert Boot media in selected Boot Device and press a key. on my netbook there is no disc drive to insert anything
The system is showing signs of issues with the hard drive, so boot to bios and reset defaults and see if the system will boot.
If not, then you will need either a bootable USB drive with you OS image loaded so you can try to attempt repairs or a USB optical drive that you can use to boot to your Operating System.
If you know the keystroke, most newer systems have built in diagnostics (Try the F12 menu) and see if the hard drive has failed.
Jun 20, 2011 | Advent Netbook
Hi, I have an advent laptop that only loads to windows when i tap the f8 button. If i switch the laptop on, it stops at the 'advent' logo and won't boot to windows unless i tap the f8 button. Can you...
try adjusting the boot sequence or at least enabling a different priority in the boot sequence ,,press F2 to get to the bios and learn how to navigate these pages
Sep 10, 2010 | Advent Netbook
When I switch on my advent laptop, it freezes and then there is a big ADVENT across the screen and at the bottom it says "press . <F12> to enter setup, <F12> to enter Multiboot Selection Menu"....
Is there any error messages? Is your keyboard working? You can try F2 to enter the setup and see whether you can see the boot options and maybe you can press F8 at startup and use the safe mode to perform a system restore or use the Last Known Good Configuration option in the advance options with safe mode.
Sep 09, 2010 | Computers & Internet
How do i go to the boot sequence menu on advent PC 7079
when you restart, quickly look out for the option that will give you access to the boot.
Jun 26, 2010 | Advent Netbook
HP Compaq NC6220 won't boot
I'm running into the exact same issue. Were you able to resolve the situation?
Fatima
May 16, 2009 | HP Compaq nc6220 Notebook
The following message appears BOOTMGR is compressed press Ctrl+Alt+Del to restart doing this produces the Advent Screen with the following options Press Delete key to run Setup Press F11 key to run Boot...
Delete key takes you into the BIOS Setting Setup that should be avoided if not sure of what it is all about, THOUGH it would be Ok to choose Load Default (Safe) Settings and then save and Exit (F10)? and Y or something like that.
F11 is a shortcut to a setting within BIOS Setup, it lets you choose Boot Device from List, normally you would try the Hard drive , as it is there that you want Windows to Load from unless of course you are trying to boot from a Windows CD/DVD then you would choose the CD or DVD from List....good luck
Apr 09, 2009 | Advent 4211c Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
