Question about Dryers
Need to get inside a maytag dryer. i think i have a dead mouse inside
  • 481 Answers
Depending on what model it is, there should be 2 screws on the bottom of the front  panel. take those out and pull the bottom toward you and unhook it from the top panel. then you can see inside the dryer pretty good. btw there is a small panel in the back you can take off to get a better view if needed.
Posted on Jun 28, 2008
How do i access the back of a Model #MDE8600AYW - MAYTAG Dryer. i think i need to replace the drum rollers but dont think i can from the front panel.
yes it can be accessed from the front panel as it is located on the back right inside of the dryer.
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) look to the right back of dryer, it looks like a spring in a metal box disconnect and replace.
Hope this helps Tim
Sep 25, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag model# MED5700TQ0 Suddenly will not start. Light inside works, so electric power is on. Could the start button have gone bad?
i would start with the door latch if its broken the dryer will think its door is open and wont turn on
Apr 21, 2010 | Maytag MED5700TQ Electric Dryer
Bad odor from dryer
A dead mouse would have crawled up fro the bottom. Carefully tip the unit back and see if you have an unexpected guest.
Feb 16, 2010 | Maytag Dryers
Maytag mde6800ayw dryer. no power at all. light works inside and im getting 220v. im told that there was a power outage and when it came back on the dryer was dead. im guessing the control board.
your guessing right then,,,
often if the power is cut off when its restored the sudden punch of power can blow the bords chips up,
its nothing new,, if they has a soft start it would not happen to them,,
sorry you need a new program bord
Oct 31, 2009 | Maytag Neptune MDE6800 Electric Dryer
Maytag mde5500ayw dryer had an oversurge of power earlier, now dryer display is dead but light inside is on. Is there a fuse in dryer?
could be one on the control board, but I will bet if you had an electrical surge theres more than just a fuse gone
Oct 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer dead!
You have a bad fuse. Will probably have to have a repairman replace it. It is hard to get to
Jul 14, 2009 | Maytag PYE2300AY Electric Dryer
How do I get the dryer apart. I have a mouse that climbed into the intake and died
not sure but my front load dryer (kenmore) has two little screws on top back of dryer which allows you access to unit....if it stays inside long enough the heat will dry out body and VIOLA no more stink!!!....easy for me to recommend from my house ....Good Luck!
May 21, 2009 | Dryers
Dryers Logo
47 people viewed this question
Top Dryers Experts
