Question about Haier HLF11P 6 cu.ft. top load washer / dryer
More on Haier clothesdryer problem
I had tried unplugging it, and that didn't work. Also just tried the door switch, which also seems to be functioning OK. Any other suggestions?
    Genius:
  • 1,122 Answers
Without a volt meter you can't really tell whats going on,your best bet is to fid a local honest appliance repair person to come fix it for you,thanks-mike
Posted on Jun 29, 2008
I have a Haier washing machine and the door is locked. I tried washing a blanket and now I can't get the door open. Help!
try unplug the washer an waiting 5 min it should unlock if , if ti does onlock you made need call a appliance servce tech
Mar 05, 2018 | Haier Washing Machines
Haier HLF11P won't start
check the door switch ,also unplug it for a minute and see if it resets itseft,mike
Jun 28, 2008 | Haier HLF11P 6 cu.ft. top load washer /...
The dryer works on the dial but when door shuts dryer dont work
Hi Lisa, Seems like a faulty door switch but that's only my opinion.. The link below is a user manual for dryer, I had a look
http://www.brandsmartusa.com/pdfs/manuals/20164909.pdf
Apr 05, 2016 | Haier RDE350AW Dryer
When the air conditioner goes on it shows "E2"and nothing else happens what can be done to solve the problem?
The E2 Code, indicates a Sensor or System Failure, But, before calling Haier, try this.
Turn the Master ON/OFF Switch to OFF & unplug the unit for 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the unit's electronics during that 15 minute timeout, have reset itself and reverted back to the original factory settings. If so, it was a false code. If it didn't reset itself, contact Haier Customer Support 1-877-337-363.
Hope this helped you. Please let me know.
Jul 07, 2011 | Haier Heating & Cooling
Touch control for humidity setting only goes up, cannot lower setting, is touch pad defective and can it be replaced or not worth it anymore
Yes, the touch pad may defective. But, before you try to replace it, let's try something else first.
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 15 minutes and plug the unit back in. Turn the Master ON/OFF Switch to ON and set the humidity extraction level where you want it. Hopefully, that 15 minute time out allowed the unit to reset itself and revert back to the original factory settings.
If it didn't you can order replacement parts directly from Haier 877-337-3639 or locate a service center near you.
Hope this helped to solve the problem. Please let me know. Thanks.
Jun 03, 2011 | LG LHD45EL Dehumidifier
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
Hope this helped you to solve the problem.
Apr 15, 2011 | Haier Dehumidifiers
Haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Won't start
you can also check you breaker, sometimes only one side of a 220v breaker will trip and the machine will still seem to have power but it does not have the full 220v. worth a try, turn your breaker off and then back on.
Haier HLF11P 6 cu.ft. top load washer / dryer Logo
64 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
