Question about HP Pavilion dv1000 Notebook
No power i have the hp zv 5000 and have no power i got the universal wall power adapter from targus i plug it in and the blue charge light comes on but goes right back off
    Genius:
  • 2,028 Answers
Try purchasing an original adapter. I've had several machine of different make through my shop that the Targus adapter just simply won't run. For example, a Dell Inspiron 1100 and HP dv4000 won't run at all, and a Dell Latitude 1501 and Gateway crv503 will run but won't charge the battery. Targus adapters are junk, if you can, get your money back.
Posted on Jun 28, 2008
Keyboard quit working; blue charge light on
faulty power adapter port, may have blue light meaning charger is working normally, double check with another working power adapter or use your adapter with another keyboard to check which device has problem, power adapter or keyboard port.
Oct 12, 2014 | Targus 90W AC Universal Wall Power Adapter...
HI there! I am using a targus universal wall power adaptor for laptops, it has an output of 19.5 V and 90 W. I was wondering if I could use this to charge my UK laptop from ADVENT. The charger for this has...
The wattage is to different, the wattage for the adapter is 90watts, and the charge for the advent is only 65w.
You can always try it, but you risk damaging your battery, or motherboard.
Jul 16, 2011 | Targus APA30US AC Laptop Charger AC...
I have no power to my zv 5000(hp). It has the power cord and everything. the charge light does not light up when it chgs... But when I first plug it in I get a 3 second spurt of blue light from the on...
First of all, disconnect your battery from back of the
laptop, then try and get a friend or a technician that
uses the same type of laptop, and try to swap the
battery just to check whether it works and charges
it properly. Also do the same thing with the
Adapter/Charger and charge it with it.
This is because, there are two diagnostic possibilities
here:
1.) It is either the battery that you bought is not good
and you need to return it quickly before its too late
or;
2.) The charger that you are using is bad, or not
supplying enough current to charge the battery
cells...and this might even damage the battery after
a while, or make the battery not to charge to its full
capacity and as well discharge quickly.
Try this out and let me know how it goes.
Hope this helps you out.
Goodluck and thanks for using fixya.
Nov 10, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Universal power supply targus tip for Dell Latitude D620, won't charge battery, pop up says slow and no (charge), use only Dell. Is there a Targus tip that will go on Model APA10 Targus Universal power...
the problem is the BIOS of the Dell system is looking for an ID signal from the AC adapter so it knows what adapter is connected. If the BIOS cannot ID the power supply, then battery charger is disabled.
You will need to get a Dell AC adapter.
http://www.discountelectronics.com/index.php?l=product_detail&p=1459
Feb 15, 2010 | Dell Latitude D620 Notebook
HP ZV 5000 laptop AC adaptor switches to battery power randomly. The AC adaptor has only one year of usage on it and it works fine when the switch to battery power problem (luckily) doesn't occur. Also the...
We have two different HP Pavilion laptops, and they've both done this. For us it hs been the AC cord itself where it plugs in to the computer that has been the problem. Personally I think it is a scam with an imminent design failure built in. The cord bends right after the plug over an over again until the cables inside start to break and or short. At first you can get it to work by angling the cable just so until the charge indicator comes on, but after a while it just gets too far gone.
The scam part for ALL laptops that I have seen is that the cable is not replaceable. You have to replace the whole adapter. Of course the section of cable from the wall to the adapter is replaceable, but the cable from the adapter itself to the computer is hard wired, and that is the only part that breaks!
I have had minor success in repairing or replacing the ends, but the best fix is to get a new one. eBay has some for much cheaper than HP.
Apr 15, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Power problem with laptop
The problem may be in the charger now. It could have shorted out. Do you see any lights on the unit when it is plugged in? James
Dec 30, 2008 | Computers & Internet
Hp zv 5000 won't charge battery or turn on
you need to remove and install the battery. Some times this works first try others may take a few trys. Mine does the same thing. Good luck
Aug 07, 2008 | HP Pavilion ZV5000 ZX5000 Compaq R3000t...
Gateway laptop not working
What is the problem with the notebook?
Do you get any lights on the notebook when its plugged in?
Have you tried another power adapter?
Dec 26, 2007 | Computers & Internet
POWER CORD
most notebook adapters i've seen have the light stay on as long as it's supplying power to the notebook. so your p/s maybe defective - my guess is that something's tripping it - are you sure the p/s is suitable for your particular notebook (based on voltage/current/power requirements)?
Nov 16, 2007 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
253 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
