Question about LG Heating & Cooling
What is energy saver mode on my LG window AC and what does it do? What is Dry mode on my LG window AC and what does it do?
  • 1 more comment
  • Anonymous Jul 02, 2008
    I have the same questions. Is dry mode meant to work on drying the room more than cooling it, or does it mean use this setting when in dry areas? No help from the manual. My model is LWHD1006R.
  • Anonymous Sep 07, 2008
    what does this "Dry Mode" do????
  • Anonymous Mar 02, 2009
    How is the "Dry" mode different from the "Cool" mode?
2 Suggested Answers
  • 159 Answers
SOURCE: lg 10000 btu ac wall unit
if you remove the front cover you should see a little sensor with a wire. you need to make sure it has not fallen off its bracket or came off form the evaporator. if it looks to be ok and mounted correctly, you may have a bad sensor and it is not able to tell the temp and not shut the unit down. also to on very hot and humid days even though you have it set to energy saver it senses it still needs to run. If you turn the thermostat up when its on the energy saver will it shut off? and if you do the same on the regular setting will the comressor shut off and the fan stay running? Let me know and I can go from there. Thanks
Posted on Aug 06, 2007
I have a window carrier ac 1.5 ton. display show 5A what is this
Its not 5A but SA means energy saver mode.use remote to change to cool mode without energy saver.
Sep 09, 2016 | Carrier Heating & Cooling
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
Ac unit keeps reading fl or full. every 2-3 hours. auto clean button drains out about 1/4 a gallon of water and then stops draining. turn back on ac & repeat process every 2-3 hours. I have tried...
After reading over the Owner's Manual for your unit, I wonder if you are operating it in the Cool & Dry Mode. If that's the case, the dehumidifier is in operation, which would account for having to drain the unit every 2 to 3 hours. Ideally, the Cool and Dry Mode should only be operated for about an hour, when the unit is first started . Removing the humidity will allow the AC function to cool more effectively. But, it is not necessary for it to remain in Cool & Dry mode all the time. Because the AC itself unit will remove some humidity too.
Hope this helped you to troubleshoot and solve the issue of having to drain the unit every 2 to 3 hours
Jun 27, 2011 | LG LP1200DXR Portable Air Conditioner
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
Is there a reset button on the dishwasher? if so, where?
Not sure what type of reset you are after. Is the dishwasher not responding to any panel switches.
Is the keypad locked, i.e., is the control lock light on? Then press Energy Saver Dry button for 4-5 secs.
Are some lights flashing and dishwasher will not start? Have you tried to turn mains power off and back on?
If you think the controller needs a reset, you could try this sequence of keys within 7-8 secs.
hi temp scrub/ energy saver dry/hi tempscrub/ energy saver dry/ hi temp scrub/ energy saver dry.
If the reset sequence has worked correctly, then all lights should light up. Press Cancel to exit from reset mode. I am assuming you have a users manual. If not then download from here.
Please rate the solution if it helps your problem otherwise post a comment
Feb 18, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
The energy saver doesn't work so we have to use
Clean and straighten the connecting vent on the rear of the dryer. Check the blower wheel attached to the motor. Make sure it is clear of lint and turning OK.
If the heat does not escape the timer does not advance in auto mode. In the timed mode the clothes steam rather than dry.
Aug 18, 2009 | KitchenAid Dryers
Goldstar room ac GWHD6500R
I read that its just simply cool with low fan on energy saver...on another site.
Aug 22, 2008 | LG Goldstar GWHD5000 wall/window Air...
Lg 10000 btu ac wall unit
Aug 05, 2007 | LG Electronic Window Air Conditioner
Heating & Cooling Logo
1,052 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
