Question about Maytag Dryers
Dryer is showing Burner Control Fault error on the display. These are large commercial dryers used at a hotel.
  • 1314 Answers
SOURCE: I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
Posted on May 21, 2008
  • 77 Answers
SOURCE: maytag commercial dryer rejects all quarter
Take out the coin slide and inspect for any worn parts. You can replace it for about $40
Posted on May 14, 2009
Illeagle
  • 525 Answers
SOURCE: commercial dryer coin op programming
Below is Maytag's commercial laundry website where you should be able to acquire the information requested.
http://www.maytagcommerciallaundry.com/content.jsp?pageName=CustServ
Posted on Jul 17, 2009
SOURCE: Commercial dryer not getting hot
Check draft switch on back of dryer have had wire ties break and wires get in way of flap.Make sure when closing door when dryer running draft switch is pulling in.If it is not pulling in check for back drat flap inside where your exhaust is hooked up have had those stick closed or someone ran self taping screws in front of back draft flap.Also check transformer if it has the old g60 gray box on top of gas valve.Check voltage at valve
Posted on Aug 30, 2010
richroth
  • 9472 Answers
SOURCE: my kenmore elite dryer will not start up,all the
There are some things about the "Check Lint Screen" light you should know. It's a reminder light and doesn't actually check anything. When you select a cycle it should come on and stay on until the Start button is pressed, the door is open or after 5 minutes.
If the Control Lock is not turned on then you may have to replace the console/interface to resolve this problem.
A hard reset is used to describe a reboot process. With the dryer stopped and the control turned off (if possible), unplug the dryer to completely disconnect electrical power. If it is difficult to reach the dryer outlet plug, you can shut off the breaker for the dryer to completely disconnect electrical power. Leave the electrical power completely disconnected for 5 minutes. This will sometimes reset a control board that is stuck due to a power surge or glitch encountered through the electrical lines. Plug the dryer back in to see if the control will operate properly.
If the control does not reset and work normally after the hard reset, then you could have a stuck "touch up" button on the control. The image below describes a diagnostic test mode that can be entered to check the buttons on the control. If you are able to enter this mode, you can check to see if the "touch up" button is stuck. You may not be able to enter this mode with a stuck button, bad user interface control board or a failed machine control board. If the dryer will not go into this diagnostic test and the console will not respond to other cycle selections, then I recommend calling a service technician to diagnose and repair the dryer. It is likely that the user interface control board will need to be replaced.
Test Mode Sheet
Posted on Dec 11, 2010
Squeaking frigidaire dryer
Take the front off and grease the felt drum slides, the belt tensioner pulley, and the bearing at the rear. Other moving parts are the motor and the fan. I used to do my commercial hotel dryer once a year because of heavy use!
Apr 11, 2016 | Frigidaire Dryers
WHAT IS THE MEANING OF CODE D16?
(D16) Gen 2 Card Reader Communication Fault This fault occurs when the control has not received a health check function from the Gen 2 debit card reader in 30-seconds. If this fault occurs in Ready or Vending Modes, the control will log the fault and display "OUT OF ORDER". Once the control enters READY Mode and the fault has not been corrected or cleared, the control will display "OUT OF ORDER". The fault is self clearing; therefore, once communication is reestablished, the control will clear the OUT OF ORDER condition and allow full dryer functionality again.
Dec 20, 2015 | Maytag MDG16PD Gas Commercial Dryer
What does error code f 02 mean?
Noted this is a Red Maytag Gas Commercial Dryer.
Using this parts link:
http://www.kitchenaid.ca/assets/pdfs/literature/Repair%20Part%20List%20-%20W10222090.pdf
And this Owners manual Link:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10057350A.pdf
I do not have the service manual for this dryer and I have yet to locate it via any source. The dryer appears to be made by KitchenAid. Even checking the KitchenAid service manuals has yet to be successful.
Inside the dryer there is a tech data sheet enevelope that will either be on the left side / inside the top console or taped to the left side of the dryer cabinet on the inside left as your facing the dryer. The F02 code should be listed on one of the 4 data sheets in that Technial Data Sheets packet. The sheet your looking for will have this number printed on it:
W10057359 Tech Sheet
I wish I could be more helpful but this one has me baffled as to why I can not locate a service manual.
Now.. having said that... are there any symptoms that you noticed before the dryer displayed the F 02 code. Like clothers were taking longer than usual to dry? Odd burner operation?
Anything out of the ordinary?
Kelly
Apr 05, 2011 | Maytag Dryers
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.
3.Press the "SIGNAL"button.
4.Press the "DELAY START"button.
5.Press the "SIGNAL"button.
6.Press the "DELAY START"button.
Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE DBVH512EFWW Dryer
Its a commercial dryer for a hotel sometimes it stops put after a while it kicks back on i presume it is over heating but why i dont know can you help
i would start by cleaning all the vents, that is in the dryer as well as the tube. After that I would run it and see if it fixed the problem. Hope This Helped Tim
Oct 31, 2010 | Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dryer showing E5 error
Ok, this is a control fault. the issue is will the logic chip set on the control board. the run-time sequence is corrupt. you will need to replace the control on this unit asap if possible.
May 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer
88 is not a error code on the tech sheet..all error code should have an F-XX I think your control must be showing a bad circurt in the control... you need to replace control... hope it helps
Sep 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
GE Dryer error code E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code “E00”shall be displayed on the 7-segment display.
After clearing all errors from the fault log, the control shall display the no error “E00”code on the 7-segment display.
Mar 16, 2007 | GE DBVH512EFWW Dryer
Dryers Logo
65 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
