Question about Olympia CDP 24201 Cordless Phone
Olympia cdp24201 I am trying to register the base unit and it keeps saying no base connected. It is plugged in to power and a phone line.
  • 3 more comments
  • gordber Jul 13, 2008
    can not get base phone too connected
  • Anonymous Sep 17, 2008
    I just bought the phone from value village but I'am unable to use it. i have a constant message that, the base is not connected.
  • igmccoll Nov 28, 2008
    I can get the base phone to work but cannot activate the second handpiece. All is fine until the command to enter the bluetooth ID, which isn't relevant since I'm not using bluetooth.
  • pierre3787 Jan 06, 2009
    I tried to "Register my handset" but to do this, I have to Press and hold "mute" on the base station for 10 seconds. I can not find a "mute" button an the base station. The only button on the Base station that can be pressed is the "Page" button.
  • LeblonMan Apr 12, 2009
    I have the same problem when trying to register my handsets to the base. In my case, my phones sat unused for years unplugged. The process above described by others begins fine but terminates without completing the registration. In my case, I suspect my batteries are too weak to complete the process. I will replace them both before moving on.
    I have a "mute" button.
The book says :
1. Press the down arrow to go to MENU, then press the down arrow to select HS setting, then registration, then register
2. My CDP 24106 base station does not have a "mute" button. In the instruction manual, there is an error and an errata sheet that came with, it says to press and hold down the "Page" on the base station for about 10 seconds. The "envelope" icon will flash, and you will hear a Beep to confirm the base station is discoverable.
3. Then press next to continue.
4. Select the CDP BASE and connect it.
5. Enter 0000 as a password.
6. You now should be registered.
Note on some base stations, there is a "mute" button, in this case, press the mute button.
Posted on Jan 06, 2009
1. go to menu, then HS setting, then registration, register
2. follow the steps and register the set to the base.
3.press and hold the base mute button for 10 seconds, press next to continued
4.select the cbs and connect it.
5.enter 0000 as a password
Posted on Sep 18, 2008
How to register a panasonic a kx-tga850e
Look on the base unit, not the charging cradle. The charging cradle merely plugs into a wall outlet for power. The base unit is the device that's hooked up to the phone line.
Aug 24, 2012 | Panasonic Lands Phones
I have a uniden Tru9466 base station and a uniden TWX 977 that the later that was previously registered with the first displayed a out of range notice so I went thru the process in the owner's manual...
Welcome to FixYa.
  1. Turn OFF your handset (TWX977) and any other handset registered to the base (9466).
  2. Unplug the base from its power source.
  3. Unplug the phone line from the base.
  4. Wait for 15 mins.
  5. Plug back the power source and the phone line.
  6. Turn ON the handset (TWX977)
  7. Reset the handset (TW977) by doing the following:
  • Press the MENU soft key. Select the DEREGISTRATION submenu.
  • ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
  • To clear other handset information, please follow these steps:
  • From the handset, press and hold [ ] and [#] for more than 5 seconds. Select the DEREGISTER HS submenu.
  • Move the cursor to select the handset ID to be de-registered from the list, and then press the OK soft key.
  • DEREGISTER HS appears. Move the cursor to select YES. Press the OK soft key.
  • ARE YOU SURE? appears. Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone.
8. Register the handset by doing the following:
  • With the base in standby, press the MENU soft key.
  • Move the cursor to select REGISTER HANDSET. Press the OK soft key.
  • On the handset, press and hold [#] until you hear a beep.
  • While the handset is registering, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
  • COMPLETE is displayed; the handset has been registered to the base. If REGISTRATION FAILED appears,
  • please try these steps again.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 22, 2011 | Uniden TRU9466 Cordless Phone
Don't I have to connect the phone to a telephone line? I don't see where i can place a phone wire in the phone. Also, I have the handset in the base but it doesn't say that it is registering. It keeps...
Often the line cord connection is on the back of the base unit or underneath, usually near where the AC cord plugs into the base unit that powers it. The handset needs to charge before it will be ready to use, sometimes for 12 hours. If after charging, it still is not registered automatically then try manually registering it to the base unit per the directions in the manual.
Dec 09, 2010 | Uniden Cordless Phone
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
TIP: IF REGISTRATION FAILED, REPEAT THE ABOVE PROCEDURE.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
Phones won't Register!!
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
Jul 27, 2009 | Uniden TCX905 Cordless Accessory Handset...
Wireless phone extension not working on receiver. Red light and horrible sound hen connection is attempted
You need to register the unit it will work:
1.
Make sure the Base Unit is switched on and has a Green light showing.
2. Unplug everything connected to the Base Unit sockets (you will reconnect them later).
3. Plug the Extension Unit into a power point near the Base Unit, switch on the power and watch the light on the Extension Unit.
4. If the light on the Extension Unit is not glowing a steady Red then the Extension Unit must first be deregistered. Follow Step A and Step B in
the Deregistering an Extension Unit box below then try to register the Extension Unit again.
5. Plug one end of a supplied line cord into to either socket on the Base Unit and plug the other end into the extra Extension Unit
(This cord is used to do the actual registering).
6. The light on the Extension Unit will glow Red for up to a minute and then change to Green or Yellow.
7. Once you have the Green or Yellow light on the Extension Unit, unplug the line cord between the Base Unit and the Extension Unit
(You can unplug the Extension Unit – it will remember being registered).
8. Plug in everything that used to be connected to the Base Unit sockets.
9. Install the extra Extension Unit as per the Extension Unit Installation steps on the other side of this page.
Apr 27, 2008 | Lands Phones
Cdp24201 base handset wont work
you just need to take the battery out and wait 30 seconds, replace it and it should be able to find the base. i had this problem and called olympia and this is the fix they gave me. It's worked for 4 years!
Sep 07, 2007 | Olympia CDP24200 Cordless Phone
Move closer to base
Either the phone is not registered to the base unit or the RF module is broken. It could be a bad battery but unlikely unless very old or you have not charged it. You should check the manual for registering the phone to the base unit.
Sep 07, 2007 | Panasonic KX-TG2584 Cordless Phone
No dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Jan 09, 2007 | Olympia CDP 24201 Cordless Phone
Olympia CDP 24201 Cordless Phone Logo
351 people viewed this question
Top Olympia Lands Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
