The blue lead does not go to negative. It needs to go to the power antenna wire from your radio. If you have an aftermarket radio, then this would be a solid blue wire from the aftermarket radio harness, that should be connected to the matching blue wire in your other store bought Toyota harness that it mates to. Then this plugs into the OEM harness that is part of your truck wiring. You can confirm that the blue wire at your power antenna is the one that triggers the motor by briefly touching it to the power wire (red) and watching your antenna begin to rise up. Remove the blue wire from power, and it should descend.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
SOURCE: Need Replacement Mast for Metra 44-PW22 Power Antenna
the online site for metra is www.metraonline.com The part number for the replacement mast is 44-PW22. Hope this site will help you find a dealer in your area. If you need more help, please ask.
