Question about Garmin nuvi 200W GPS Receiver
Garmin nuvi 200
Keeps returning to a screen that says "updating gps firmware". After it says updated 100%, returns to same screen and repeats the process!
  • Anonymous Jul 07, 2008
    My Garmin Nuvi 200 just did the same thing to me this week (7/04/08). Should I be worrying? I'd never seen it before, and thought that perhaps it was updating on the fly somehow.
    Scholar:
  • 162 Answers
Try updating via Webupdater even if you've already done so. There seems to be a problem with the update and doing it again seems to fix it. When updating, and it's already updated, there will be an option to reload it. Do it and post the results.
Posted on Jul 26, 2008
My Garmin Nuvi 1490 LMT returning to normal functionality after doing a map update.
Common problem caused by a failed map or firmware update...or both.
Corrupted map or firmware files prevents the unit from booting normally. More info on boot-up problems here:
http://www.sharc.net/gps_bootup_repair.htm
Apr 07, 2013 | Garmin Nuvi 1490LMT Nuvi 1490 w/ Lifetime...
Nuvi 200 'Updating GPS Firmware 1%' Problem
there is actually a problem lots of people have with this unit and it seems in the FAQ i can find through garmin that it can take up to 30 minutes to aquire the satellites. there is no fix but if it has the option to get a additional antenna i would try so. If not id suggest a new unit.
Jun 18, 2008 | Garmin nuvi 350 GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
Have accidently wiped mapping from garmin sat nav
I can help you fix your Garmin Nuvi 200.
The error message you are receiving about maps is actually a sign of a firmware corruption problem, which just happens from time to time with electronic devices. Updating the firmware of your nuvi will replace the corrupt firmware.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software. Occasionally a nuvi 200 will also need a Hard Reset (preceded by a favorites backup) to bring it back to 100% operation.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 09, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 - continually updates firmware
I can help you fix your Garmin Nuvi 200W. You will find the newest version WebUpdater if you follow my links, released March 31, 2010. I think you will find between a Hard Reset and the new software, your Nuvi will be better than new again.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 22, 2010 | Garmin nuvi 200W GPS Receiver
How do I update my Garmin nuvi 200 GPS?
There are three steps to take to update your Garmin Nuvi 200:
I hope that helps.
Jan 10, 2010 | Garmin nuvi 200W GPS
Every 30 seconds my Garmin Nuvi 200 displays a dialog box that says "Updating GPS Software 1%" followed by "GPS firmware update complete [OK]. Whether you press OK or not, the screens pop up again after 30...
did anyone find a solution to this problem? I have exactly the same at the moment. I've tried number of times to update it by webupdater, to reset it... practicly everything with no success. Thanks!
Nov 22, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
So what happens when you connect it to the PC?
Make sure no sd cards are installed while you do this.
download and install web updater, run it it gets to a screen where it looks for the gps, plug the usb cable into the GPS (no USB hubs please!!!) Make sure it detects the GPS before you continue. Select the updates you need (don't install all the languages !!) after this is done the program will report the downloads are on the garmin, unplug the unit and it will reboot and whilst rebooting it will install the updates....so don't touch it until it reboots again and displays the regular screen....and make sure the batery is fully charged before you do this...!
Jul 23, 2008 | Garmin nuvi 350 GPS Receiver
my garmin nuvi200 keeps on searches for satellite,but it couldnt able to pick up signal. A question mark over a map is always im seeing througout
Apr 06, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
274 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
