Nokia 5200 Cellular Phone Logo
Posted on Dec 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In my n5200.if i want to clear the packet data counter in the log category, i am asked to enter a security code. i have tried 0000 but to know avail.please what is the solution to this, is there a kind of master security password that i can use to reset this
  • sam Dec 09, 2010
    is the phone asking for a security code or the PIN code?
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 21, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2467722
Points
19564
Note that,12345 is the factory master code for nokia. If fails, get the code at www.nfader.su
If still fail , get it unlocked at www.unlock-zone.com
Jay__GTG
Unclock security code
Steps to perform Master Reset
All configuration settings will be set back to their factory defaults. Personal data and downloaded content, however, will not be lost.
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Phone Settings.
  4. Scroll to and select Reset Settings.
  5. Select Master Reset.
  6. Select Yes.
  7. Enter Security code, then press OK. The default security code is 0000.
Steps to perform Master Clear
All configuration settings will be set back to their factory defaults. Also, all personal data (including contacts) and downloaded content will be erased.
  5. Scroll to and select Master Clear.
  6. Select Phone.
  7. Select Yes.
  8. Enter Security code, then press OK. The default security code is 0000.
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur.
How can i delete recent contact during messaging?
Hi, please open the Menu>Log Menu and select Message Log. Then, select Clear all counters. The phone will ask for Security Code, enter the security code as 12345. That's it, the Recently used contacts will be cleared.
Were is the reset button
There is no reset button. In order to reset phone, you can perform following steps.
Performing this function will reset all user-defined settings on the device.
  1. From the standby screen, tap the Menu icon > Settings > More > Reset Settings > Master Reset.
  2. Tap Yes after reading the warning.
  3. Enter Security code, tap OK. The default security code is 0000.
This will erase all data (pictures,address book,any downloaded content) and reset any user defined settings on the device.
  1. From the standby screen, tap the Menu icon> Settings> More> Reset Settings > Master Clear.
  2. Scroll to and select Handset.
  3. Tap Yes after reading the warning.
  4. Enter Security code, tap OK. The default security code is 0000.
5helpful
My cp is nokia N70... my problem is its says "memory full delete some data first" ive already format my memory card so then my free mb is big but its the same problem nothing changes i have a...
YOU NEED TO FORMAT YOUR PHONE NOT MEMORY CARD.FORMATTING THE PHONE WILL SOLVE YOUR PROBLEM.AND TO AVOID PROBLEM IN FUTURE INSTALL APPLICATION MANAGER ON YOUR PHONE AND WHENEVER YOUR PHONE SAY MEMORY FULL JUST USE THIS SOFTWARE TO COMPRESS MEMORY.
THERE ARE TWO METHOD TO DO FORMAT NOKIA HANDSET.
  1. MANUALLY.
  1. OPEN MENU>SETTING>PHONE SETTING>FACTORY SETTING.
  2. PRESS O.K. A MENU WILL POP UP LIKE YOU LAST ALL YOUR DATA PRESS O.K.
  3. IT WILL ASK FOR CODE ENTER CODE( DEFAULT CODE IS 12345).
  4. PRESS OK IT WILL DO FORMAT YOUR PHONE.
2. USING CODE.
  1. DIAL *#7370# ON MAIN SCREEN.
  2. A MENU WILL POP UP LIKE FORMATTING PHONE.
  3. PRESS OK IT WILL ASK FOR CODE ENTER 12345 AND PRESS OK
  4. IT WILL DO FORMAT FOR YOU.
3.METHOD NO.3(FOR S60 SERIES MOBILE)
  1. SWITCH OFF YOUR PHONE.
  2. WHILE SWITCHING ON PRESS THREE BUTTON AT THE SAME TIME.(1.GREEN DIALING KEY 2.*KEY,3 KEYPAD NO. 3 KEY) WITH POWER ON BUTTON.
  3. A MESSAGE WILL POP UP LIKE FORMATTING. HOLD BUTTON FOR 3 SECONDS AND RELEASE THEM AFTER THAT.
  4. YOUR PHONE WILL RESTART AND ALL YOUR DATA WILL BE GONE
2helpful
I forgot my security code, what should i do? i want to format my lg gd510 phone but it need security code and i dont know whats the code
BEFORE COMPLETING A RESET, BACKUP ANYTHING YOU HAVE STORED ON THE HANDSET, THIS INCLUDES CONTACTS *
  1. Tap the menu icon : :
  2. On the Settings section tap Phone settings
  3. Tap Reset settings
  4. Tap Yes to the question All settings will be reset. Continue?
  5. Enter the security code 0000 then tap OK
If you wish to delete the phones menory of all your images, music, contacts etc then,
  1. Tap the Menu icon : :
  2. On the Settings section, tap Phone settings
  3. Tap Memory info
  4. Tap Handset common memory
  5. Tap Reset
  6. Tap Yes to the question Do you want to delete licenses also?
  7. Tap Yes to the question All data will be cleared Continue?
  8. Enter the security code 0000 and tap OK.
Hope this help and if helpful RATE please.
4helpful
2answers
I want to reset the LG shine 720
Hello thanks for using FixYa
To hard
reset of
your cell
Type 1809#*500# & select reset option which restores the factory settings.
A confirmation screen will appear, select Yes. It it asks security code then enter 0000 it will take some time and your handset will be restored to original settings.
or try this
to Reset Default
Scroll to and select Master Reset
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
2helpful
I forgot the lock code on my application log-packet data-clear packet data...i entered 12345 code..because they say that., this code are the default code for nokia users...my phone is nokia 6120c
hi,
right that code is the default for nokia. maybe your unit lock code is change that is why it will not accept it.
your lock code can be viewed using gadgets to fix mobile phone and purchasing it is costly for just that purpose. To save time and $$$, just have your unit serviced at your nearest service center.
Hope I helped you and don't forget to rate me.
Thanks..
best regards,
john
How to clear timers of incoming and outgoing calls in the nokia phones
Go to Menu - Log - Clear log list - Clear - All call list, select this - if a security code is asked then enter 12345 (this is the default security code).
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
