2000 silverado.. radio will not stay on. goes back to 1.00 and shuts down. tried another radio, same result. i installed a scanII may be related. thanks Erik
  • 1,879 Answers
Greetings,
Make sure you met all the program's requirement.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 28, 2008
I Have a 2000 S500 Mercedes , My Radion and or CD Player goes completly out sometimes the screen even shuts off. Then turns itself on automatically then shuts back out . Im driving around with NO SOUND...
is it an after market radio? if so it might not have enough power so it goes to pull power when its turned up and its not there so it just shuts off. try checking your radio wires and your fuse.
Dec 18, 2013 | 2000 Mercedes-Benz S-Class
No power to radio pontiac grand am 2004
Do you know how to do automotive electrical testing ? Following wiring diagrams , checking B+ voltage at different points along the circuit . Did you use a interface module with the aftermarket radio ? The GM radio is hooked to the class 2 serial data network . Your best bet , take it to a qualified installer .
Apr 04, 2017 | 2004 Pontiac Grand Am
Truck goes plum crazy while driving.
I strongly suggest you contact a local dealer, I have never seen this symptom on any GM vehicle. I think you have a loss of battery power for some reason or a faulty ground, where that may be is another story.
Mar 17, 2017 | 2007 Chevrolet Silverado 2500HD
Pc won't start
Think your power supply died. Check that out first since they are relatively inexpensive. Or throw in a known working PS to see if that does the trick. Write back with results for further info.
Sep 17, 2017 | Packard Bell iMedia Computers & Internet
I have a 2008 chevy silverado and was going down the highway and a message came up in the odometeterENGINE POWER REDUCED! and started slowing down i pulled over and shut the engine off and started back up...
This is a 'limp home mode' and is engaged if a fault is detected that may result in damage to the engine if allowed to go unchecked. Take the vehicle to a dealer or Autozone and get a read out of the stored error codes from the on-board diagnostics module as this will help define the exact nature of the fault.
Dec 29, 2010 | 2008 Chevrolet Silverado 1500 2WD
Just installed aftermarket radio and the engine shuts off after a few seconds after hookup. why
if this is 99 up truck security system is shutting it down trucks are very hard to change radios in even with radio from same year from salvage yard your radio and bcm must match vin #. say with factor radio or take it to radio installer
Sep 19, 2010 | 2005 Chevrolet Silverado
Have 2005 chevy silverado the intrument cluster lights stay on also the radio stays on and the battery light in the cluster is on ,replaced the igntion switch, the dome light go out when u shut the door...
I had the same problem. I had to check the fuses in the engine compartment, I then had to replace two 15 amp fuses, after I replaced the fuses the problem was gone.
Jan 10, 2010 | 2005 Chevrolet Silverado 2500HD 2WD
2000 chevy silverado stuck on defrost
with the truck turned off pull the gear selector down to 1, tilt steering wheel as far down as it will go. now on the dash pull the trim ring 'bezel"
this is the piece that goes aroung the headlight switch over the gauges around the radio and the climat contols. once that is off the switch has to clips on on each side pull back both at once or one at a time the module will come right out
May 07, 2009 | 2001 Chevrolet Silverado
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
